jchandler3
Just ordered mine last night. Impressions to follow!
That seems a very nice choise, as it is the same as the original stepdance and the mono version of the OPA1612 used in the DACport.
just got a reply back from Ibasso, the D7 uses OPA1611
The line output stage is based on the Texas Instruments OPA1611 op amp, chosen for its superior sonic quality. The OPA1611 is one of a new generation of operational amplifiers fabricated using a SiGe bipolar process, which allows for a higher current gain and higher speed than a Si bipolar process.
Also it shares with Anedio D2 (1470$) the same reciever XMOS chip.
I see D7 is really a bang for buck.
Not only. OPA1611 is also used in Anedio D1 (1270$) output stage.
So why ain't you getting one?
Hi there,
this is my first post.
I've got my D7 today and installed it at my desktop PC with Vista. Everything works fine.
Then I wanted to install the little device at my music PC that runs Win XP SP3. The setup of Thesycon stops at some point and asks to disconnect and reconnect and power-on the device. The setup runs some time and then it stops or better sleeps. I have to kill the task. After restarting the system the D7 is recognized on my PC but when I choose the TUSB ASIO driver in Foobar there is no sound out of it. The sound comes out of the old device via SPDIF.
Has anyone some hints to get it working with XP?
Thomas
Is it possible to use iPad > Camera Connectin Kit > powered USB Hub > iBasso D7 ?
Can anyone confirm?
Thanks
Yep.
Just ordered a D7 today. I'm hoping it will be a solid upgrade over my Fiio E7. Pretty excited to get it.
