Hi Poimandres,
I bought my Moon Audio Silver cable from a fellow headfi.org member. It is the type with a mini XLR connector (like the connectors fitted to Audeze headphones) at the bottom which allows you to fit any type of connector adaptor to it i.e. kobicon balanced connector, double XLR, single XLR, 1/4" jack etc.
As the HD650's are a tad dark and the Cypher Labs Duet is a touch warm I would recommend you go for a silver based cable.
The difference between the stock HD650 cable with a standard jack connected to an adapter to fit the Duet and my Moon Audio Silver cable with balanced connector is like night and day with everything i.e. music clarity more bass, bigger soundstage, more power etc.
