I'm ordering a very expensive 2 pin cable and I need to make sure all my points are covered for compatibility.
1. This IEM has 0.75 mm pins? The cable maker has informed me they have 0.75 mm pins.
2. Anole VX has reverse polarity: If I simply reverse the pins, is this issue solved, or are reverse polarity cables different so much so that I could potentially damage the IEM by reversing the pins? Would sound quality or functionality be affected?
Thank you
Thank you
