obobskivich
A) I already mentioned owning this part, and currently the XHD3000 is the only LCD in its size (or near its size) that ships with video scaling built in, some smaller 22's or 24's may have scaling, but it isn't HT grade usually, its an inexpensive processor, and none of the 26's, 27's, or 28's that I've seen offer anything like this
B) it is NOT foroudja, there are better alternatives, namely, the gateway uses HQV Realta from Silicon Optix, which is VASTLY superior to Faroudja imho (i've seen both, I own the one with HQV)
C) it looks fine for 480i playback, DVDs from 480p look pretty decent, 720p looks a bit less than it should, but anything from there up looks proper (1200p looks stunning, as does 1600p)
Originally Posted by Edwood /img/forum/go_quote.gif But watching 720p footage on a 1920x1200 LCD is not nearly as sharp as on a native 1280x720 LCD. DVD's? Even worse. Unless you have a Faroudja upscaler built in, that is. There is a Gateway monitor that has one built in, and is supposed to look fantastic. |
