greyforest
cary dms800+hqplayer coreWhat DAC and Upsampler are you using?
You can use HQ Player within windows, and if you replace the OP AMPs of the AE-9 with sparkos then you will get an amazing sound.cary dms800+hqplayer core
ae9 is fine i am sure of it, just there is no reason not to use desktop equipment when it is thereYou can use HQ Player within windows, and if you replace the OP AMPs of the AE-9 with sparkos then you will get an amazing sound.
