evillamer
- Oct 5, 2004
Seems that the Sound blaster X7 LE might be a better deal than Geek Pulse and Aune S16.
@evillamer
Exactly what i thought at first. But then people who purchased the Pulse are interested in 2 channel audio only.
If Creative ever made a more audiophile spec X7 at a reasonable price, they will absolutely murder the competition.
Right! Forgot about it, thanks! I've updated the specs.
The unique size makes people wonder how much space it will take on the desk. We are using metric here in Singapore, so the number is more round number on cm.
Dimension:
Width : 15 cm
Height : 13 cm
Depth : 15.9 cm (including Binding Post terminal)
http://wireless-speakers.specout.com/l/1178/Creative-Sound-Blaster-X7
Here the specs made me think it was much bigger. 24cm of height!
Heppy is much smaller! I'll definitely get one tomorrow.
I'm surprised I couldn't find the specs here, which is supposed to be the main website for the product.
http://www.soundblaster.com/x7/
Oh well, everything is clear now
@earfonia : would be interesting if you can test the Dolby decode part. I can't get the Dolby LED to light when playing Dolby Digital content on a 5.1 system. I'm using a Blu-ray and PowerDVD 14 and yes the audio Stream is Dolby Digital encoded. Yet the X7 doesn't seem to recognize it... Any idea how Dolby decode works ?
Thanks !
Dolby Digital LED on the X7 will only light up when DD(Live)(5.1) is coming through the X7 Optical INPUT!
PC Dolby decoding sofware will decode it directly into PCM Audio Stream into USB Audio, hence bypass X7 built-in DD decoder.
And if you meant connecting X7 Optical/Toslink Output to another external 5.1 DD surround system/receiver's Optical Input, then you will need to set Windows Audio Device to X7 Optical Digital Output and the Advanced tab to Dolby Digital Live.
So that means DD decode is available only on incoming optical streams, regardless of the output source (2.x/5.x/Analogue/Digital) ?
BTW why on earth Creative doesn't provide DD/DTS encoder for the X7 ?
Thanks !
