SaLX
- Sep 25, 2013
(This thread)
SBX seems to work way better as long as "stereo" speakers are set in windows control panel. Obviously needs "enable audio enhancements" in the Advanced tab to work but worth pointing out. Stereo speaker config + headphones and it works very well for me.
I've just gone and closed the external link to where I saw that it was for disabling 3D sound ??? RPG's post above seems to support this even idea though it's not the normal way to do things.
Originally Posted by xand1x
I just built a new system and I have a bit perfect ENVY24MT sound card (Onkyo SE-90) and on board audio output via optical only. I am getting HDCD (red light on my dac goes on) to be passed through via Direct Sound. The key to getting things "bit perfect" for me via direct sound was to go to the advanced tab in windows sound and change 2 things. 1) Set it to output 2 channel, 24 bit, 44100Hz 2) Uncheck the box that says "Enable audio enhancements". The results above imply that you can get bit perfect output via direct sound but it would be nice to find another method to verify if I am on the right track. Any suggestions?
Originally Posted by somestranger26
If "Audio Enhancements" are enabled, you're guaranteed not to be getting bitperfect audio. Frequency settings matter a significant amount, you should always match the output frequency with the source material's frequency when possible (usually 44.1kHz, what CDs use). Bit settings matter not, if you play 16-bit content and have it set for 24-bit it doesn't modify the sound, it just adds 0s.
Maybe opening a support ticket to Creative might help as I'd really like to know. I can't find much of anything on Head-Fi (surprising at it is setting USB DAC users will have to be aware of). Will have a trawl later.
*Edit* Have contacted Creative about this and asked for an immediate escalation sent to their top-drawer tech guy (or girl). No matter the gender, he'll be called 'Dave' .. again.
