Sencha
- Sep 25, 2016
If surround position is of high importance then no I can't recommend which is a shame as it does everything else superb.
Sounds like it will be perfect for you. The sound quality will blow the mixamp away! Go for it!
No, however reduce the Audio Level of the device through the Ps4 device menu and set it to 80%
Else you will get clipping
They would have to give Dolby or DTS $$$ since that's what the PS4 can output.
The GSX amps are driver and software free on PC, you configure them as 7.1 sound cards when you plug them in, this isn't possible with consoles.
Well the GSX1000 has just popped up on amazon.co.uk for release tomorrow. Just ordered one. Will update how the surround is.
