Is this the one in your SEX amp?
Thanks!
Yes its the same as used in my Sex, I have fitted them to a couple of amps so far and the first thing I used one in was a home made passive pre. First assembling one using the metal films selected from their option page which by the way looked identical to those in my Valab these worked well enough but for the Sex I wanted to push the boat out and ordered the RN55 Dales from mouser. Using the list of values that comes in the nice little instruction book which comes with the A5.
I used a spare Crack enclosure to mount it in which was a tight fit width ways think I had to sand a fraction of the end of the pcb to get it to fit but can not actually remember. I ended up cannibalising the pre amp to use the attenuator in another amp build.
I was eager to see how it sounded so in pic of the passive pre below the input selector switch is missing but I also purchased the Select 5 pcb based switch from same people
http://glass-ware.stores.yahoo.net/select5.html to use for the selector switch.
