oicdn
- Aug 28, 2006
I bought a cheap laptop for the purpose of staying connected while out and about without having to lug around a 17 incher.
It has a T5500 Intel Core2 Duo processor.
Temp readings are:
CPU Temp: 71-72C at max performance (continous max CPU speed), 63-64C with dynamic switching
HD Temp: 41-42C
Is that running hot? I know intel chips run hotter, but is it running HOT? Intel spec sheet say it's 100 degrees.
Intel® Core™2 Duo Mobile Processor T5500 - SL9SQ
So is 72-72 degrees normal if 100 degrees is what it could rise to? I don't quite understand what the 100 degrees specifies. Is that max temp or what it's supposed to be at?
The program I'm using is NHC 2.0. Good program?
Temp readings are:
HD Temp: 41-42C
