Cozoy Aegis - 192kHz 24bit DAC/amp - Compatible with Android and iOS!
- Thread starter DJScope
Baycode
- Dec 21, 2004
New room for my baby
Water proof, shock proof... (in to some degree)
Hawaiibadboy
BANNED
Looks cool..
I gotta ask where you got that case....can a brother get a link...please
myemaildw
- Jun 10, 2014
Looks cool..
on ebay about 2 euro, i got one but its too big i think
NeObliviscaris
Niiice!
Previously known as FeedMeTrance
- Aug 6, 2007
+1 for getting the link to that case!
Baycode
- Dec 21, 2004
Looks cool..
I have to mention one thing before your order. This case's closing lids and top cover do not have a real "hinge" mechanism, it is continuous plastic, so over time these parts might break due to movement.
Other than that, case's built quality is very good and the asking price is really cheap. It even have an o ring on it...
I have tested it under shower (moving tap water) and inside was dry. Then I put it underwater (10cm below the surface) for 30mins. Very minimal water entered...
http://www.aliexpress.com/item/Outdoor-Shockproof-Waterproof-Airtight-Survival-Storage-Case-Container-Carry-Box/32393373917.html?spm=2114.01020208.3.2.qk3slN&ws_ab_test=201556_6,201527_1_71_72_73_74_75,0_0
Please check the dimensions from the page. May be it is not very small like an Aegis, but enough space to hold small audio parts, cables and iems.
Trying2Learn
- Jan 28, 2015
Can someone clarify for me the difference between the Cozoy Astrapi and the Shozy Lanzea?
myemaildw
- Jun 10, 2014
which is better cozoy aegis or c5d dac?
- Dec 30, 2013
Your question is too vague. Can you be more specific about what you're lookin for?
Which DAC used in this device?
- Dec 30, 2013
Cozoy's secret sauce DAC :wink_face:
Seriously, they don't divulge and remove markings from the chips so the competition has a hard time reverse engineering.
myemaildw
- Jun 10, 2014
is there like a cable with a volume wheel that wont reduce quality? this dac is just too loud on lowest volume for 16 ohm earphones.
no gradual volume on iphone on cozoy aegis dac is ridiculous. also not every volume step changes volume sometimes two steps are the same volume.
- Jan 30, 2011
If you're using an iPhone / iDevice - buy the Kaisertone app. it has an adjustable gain which means you can then control the volume in minute steps.
myemaildw
- Jun 10, 2014
cozoy aegis dac makes my denon d400 with smsl sap-5 bass amp with bass on sound nice, but man what happened to gradual volume? astel and kern ak10 dac has gradual volume slider when you slide on the volume on ios so i know it is possible. tim cook should put a preamp slider in settings.
- Dec 30, 2013
Yup, Brooko and I noted this earlier in the thread. It does drag the Aegis down, and I hope Cozoy changes this with future iterations on the Aegis.
That's what I did, too. NLNH recommended KaiserTone and NePlayer to me. He told me he actually prefers NePlayer, though.
