pekingduck
- May 16, 2009
If you like the UI of the AK240 why not get the AK100II or AK120II?
I used to have the ZX1 and it works with the Hugo with a combo of two cables, the specific ZX1 line out cable and a usb to mini usb cable. The UI is IMO the best there is...can't do anything about memory though.
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
On price Japan you can buy it together with the ZX1. Check the reference there.Where can I get the cable from?
Finally the P1 is available through local dealers in Singapore.
Will try to find time to compare it against my AK100II
Song Brothers? Saw their FB, and suggested retail price.
If you do get, i'd recommend jetaudio's Ebay page
Thanks for the suggestion.
I can get it lower than the RRP.
If buying from overseas, I might be hit by 7% tax for any item with value >S$400 and the hassle in claiming warranty
You can get it for USD 900. Which would still be cheaper than their best price even after tax imo.
Seems reasonable as using AK240 for transport only is a waste. But then for transport only a ZX1 is good too and even cheaper.
