hyogen
- Feb 11, 2012
hoping the above setting will sound the same on the D3 -_-
Hello,
Do you know what's the best settings for Klipsch S4 ?
I got excellent sound with iTunes with my macbook pro with default eq.
I'm trying to use BBE Vita 2 but it's not really good..
Thanks
any good settings for gr06?
i get excellent output from my realtek card (laptop) but i get "boomy" bass on my cowon. any ideas?
Originally Posted by H20Fidelity
My triple-fi 10 settings.
EQ tab:
80Hz +10 Wide
500Hz +2 Wide
1.1kHz -3 Narrow
3.0kHz +3 Wide
9kHz +6 Wide
I don't have the GR06, but for boomy bass, you should make sure the Mach3Bass is set to 0/off. Then using one of the 4 custom EQ settings, reduce the low frequency (80 Hz or so) on the EQ a couple of notches, and then probably reduce the mid-low frequency (200-300 Hz) several notches, all to your taste. You could raise the mid and 2 high frequency bars a bit to compensate for the strong bass. You can also bump up the BBE+ setting and turn on the MPEnhance, both of which tend to "brighten" to sound some -- all according to your desired sound.
I use all 4 of the user EQ sets, one for each of the 4 different phones I use. My goal is to compensate for the slight deficiencies for each phone to create a fairly balanced sound no matter what phone I use.
Wow, I thought the TF 10 already has a V-shaped sound -- your settings push that even further. Guess your getting some serious bass and sizzle!
