Originally Posted by Uncledan
This is a quick question for subwoofer user. I am new to sub and I just buy a used Rel Q150E. The Rel sub comes with 2 inputs which is Unbalanced RCA (phono) connectors and Neutrik Speakon connector. I want to check the sub is working fine, however, I don't have a Neutrik Speakon cable and I only have a stereo amp. Can someone explain to me how to connect my sub to my stereo amp? How to use the Unbalanced RCA (phono) connectors?
To use RCAs, I believe your amp would need to be equipped with an internal processor (crossover) and an RCA output designed specifically for a subwoofer. [This signal would be low frequencies only, and the volume control on your amp would also control this signal.]
According to RELs web site, you can however use the Speakon connector...
"For audiophile 2-channel applications in particular, REL recommends the use of the high level input from the host system amplifier’s loudspeaker terminals. In this way, a REL sub-bass system receives the same signal and will thus reproduce the same character of bass as the host system’s loudspeakers, albeit at still lower frequencies.
A REL sub-bass system provides the opportunity for true system integration and a means to deliver the added bandwidth required for true high fidelity."
This method would deliver low frequencies via the REL. Your main speakers would however still be full-range, as there would be no processor (crossover) to subtract low frequencies.
This again from RELs website...
"The Neutrik Speakon plug pin configuration is as follows:-
The pins in the Neutrik Speakon plug are numbered 1+, 2+, 1- and 2-
1+ connects to the right hand speaker red terminal at rear of amplifier or speaker
2+ connects to the left hand speaker red terminal at rear of amplifier or speaker
1- or 2- connects to either right or left speaker black terminal at rear of amplifier or speaker"
Good luck.
