paloalto00
- Aug 24, 2013
Do you have the smae problem with your pair? Also did you have a problem getting them loud enough without an amp?
No, not really. It all worked as it was supposed to...
The whole MA/BA/dynamics topic does bring into mind the idea - 10, 20, perhaps even 30 years from now (depending on how slow the industry adapts), how those graphene tranducers will play out. It won't be in the near future, but it's titillating to think about.
The JVCs seem to simply have CNT coating though, nothing full fledged, which will be too costly anyway. Not only that, they seem to have trouble controlling the thing...
From what I understand (and I don't seem to understand much these days), the current implementation of carbon nanotubes is simply as a coating for a still-dynamic microdriver.
One of the things I want an iem to do is isolate well. What is the best isolation among your favorite dynamic drivers?
... This is the reason why I consider products like Ety's ER-4 series to be seminal breakthroughs, even to this day.
But then shortly after BAs came along, we all realized that maybe their LF response was a bit lacking at times? Cue the multi-BAs and moving armatures and what-not. Was it a perfect solution? Not by a long shot. But it was still better than a single BA.
Tread carefully, Mr warrenpchi, you don't want to upset the Ety crowd.
Lol, got an ER-4PT and an ER-4S here... I'd only be upsetting myself.
The FI-BA-SB (aka Heaven S), FI-BA-SS, and the older FAD Heaven models did not use MAs (moving armatures) but something different FAD called BAM (balanced air movement).
^This. I think it was established that this was basically a vented BA.
... even when the FADs' distortion levels are ... er, pretty atrocious.
Measured distortion is admittedly high, but I personally don't have a problem with it at my usual listening volume. Note that Rin's distortion measurements are taken at 100 dB sound pressure level.
