- Jan 30, 2011
If T1's balanced and natural sound signature fits your aural requirements, as it fits mine as well, then you will find LCD2/ V1/V2 as unacceptably unnatural and 'dark'.
Yours is a pretty good summing up of T1 but I have to add a note - I could not find out what the output impedance [o.i.] of Little Dot MkIV is but considering that this amp accommodates headphones with 32 Ohm impedance this indicates that its output impedance is too low for T1. On amplifiers with low .o.i. T1 sounds a bit thinner. On an amp with the o. i. of at least 100 Ohm T1's voice deepens, there is more bass quantity. The tones also gain more weight. The amplifiers which Beyerdynamic makes for its 600 Ohm headphones have 100 Ohm impedance output.
In your review you did not do impedance matching for T1.
Thanks for the thoughts on the LCDs - I think I'll have to listen to them at some stage, but I guess that was what I was expecting though.
AFAIK the LD MKIV is around 40-50 ohms on the output impedance. It is a true OTL - so ideally suited for the T1. It's probably not ideal for the lower impedance K812 though - although when I tried the AKG on both my NFB-12 (very low OI) and compared to the LD, there really wasn't that much of a sonic difference.
And I didn't do impedance matching on the amps - because if I want to run the two headphones through the same gear for a side-by-side match, there is no amp that will supply a correct damping factor (according to your theory of T1 needing 100 ohm+).
I find your theory of needing at least 100 ohms OI for the T1 intriguing. I understand the theory behind a too low damping ratio - but not so much too high. As long as the headphone is getting enough voltage and current it shoudl be fine. LD MKIV delivers both to the T1. I've never felt that it has been bass light or thin on my system.
