velmeran42
- Oct 7, 2003
Okay, I'm putting some basic info here at the start of the thread in case people aren't willing to read the whole thread:
1) I'm not using a PCB, I'll be doing point to point
2) Yes, those are SMD tantalum capacitors in the photo, they're for my power rails (only two of them, the other one was just to get my digikey order over $25)
3) I haven't began machining anything yet, but I will probably get started this coming week (around Halloween)
4) I'm no longer planning on using any plexiglass, the logo in the front will be epoxy with silver particles suspended in it (a professor suggested the silver particles and is supplying them)
5).... ummm, I don't know, the "black thingy" is a 400mAh 11.1V Li-po cell with protection PCB
img added 11/9/06
img added 11/14/06
img added 11/15/06
img added 11/22/06
img added 11/22/06
img added 12/1/06
img added 12/1/06
img added 12/8/06
img added 12/8/06 (This one is an AlienDAC case)
img added 12/28/06
__________________________________________________ __________________________________________________ _______
(original post starts here)
OK, I've only got a few minutes before I have to hit the bus...
I'm machining an aluminum and plexi CMOY pocket case for a CNC machining class (details to come later today).
I'm trying to build a "top shelf" CMOY w/o going to crazy (bit late for that really), and I want to keep size down as much as possible w/o taking a quality hit.
I'm using a 400mAh Lipo (11.1V) w/ protection PCB, (57x24x18 mm) for the sake of power density and coolness factor. This is the only component I already have on hand. For everything else, please feel free to make comments / suggestions.
OPA: AD8620 - low voltage cut off, good current supply, good sound. It'll play fine all the way up to when the Lipo's protection circiut cuts off.
Resistors: Vishay Dale 1/8 1%, as per parts list except for a gain of 6, no R5, and RLED of 1K ohm (in front off 4 low current red LEDs in series giving them the 2mA forward voltage they need right up till the power dies)
Virtual ground: TLE2426 w/ 220uF 16V Panasonic sitting on battery side (would it be a good idea to cap the output rails, if so, how much?), not sure on the CNR, probably a Panasonic as well, but the lowest V is 50, so the cap is a bit bigger than I'd like. Any suggestions on something smaller for that location?
Pot & Power: ALPS RK097 from Tangent. Seems to be the best compromise of quality and size, like the integrated power switch.
Input Caps: I really don't know what I want to use here yet, I really don't want to sacrifice on quality since this is such an expensive project. Any recommendations available from Mouser or Digi-Key (supperior to the Panasonics on the parts list).
Thanks for any input guys, gotta jet.
Edit: changed thread title to say I put in some pics 11 Oct 06, 11:28pm
img added 11/9/06
img added 11/14/06
img added 11/15/06
img added 11/22/06
img added 11/22/06
img added 12/1/06
img added 12/1/06
img added 12/8/06
img added 12/28/06
