infinitesymphony
- May 15, 2006
Here is an updated version of the parts list I used for my three great-sounding Joshatdot PCB CMoys. I ordered most parts from Digi-Key, but the Alps potentiometer must be purchased elsewhere. amb stocks it and a few other essential parts, so I ordered from him wherever possible to avoid the handling fee for a small order.
Code:
Code:
Code:
Code:
Notes: Feel free to substitute a higher-valued Panasonic FM radial capacitor for C1, since 470uF can barely fit directly on the board anyway, or a lower-valued C1 if you plan to fit the amp into a standard Altoids tin. In general, higher capacitance = taller, higher voltage = wider. C2 input capacitors are only necessary if DC offset from your playback device is a concern; most devices have output capacitors. R5 resistors are only necessary if you have very low-impedance headphones.
The amplifier's gain is a multiple of the original signal level from the playback device. For example, a gain of 5 means that at full volume, the amplifier will be 5 times louder than plugging directly into the playback device's line output. You can change the ratio of R4 and R3 resistors if you want a gain other than ~5.54, which is the result of the combination in my list. Gain calculation uses the formula: (R4/R3) + 1. Stick with a gain of above 5 for maximum compatibility--certain op-amps are not low-gain stable.
I highly recommend adding decoupling capacitors to the bottom so that the use of the National LM4562 op-amp becomes possible--it sounds great!
Code:
Code:
[left][b]Resistors[/b] 2 - R2, RES 100K OHM 1% 50PPM 1/2W, Vishay Dale [CMF100KHFCT-ND] 2 - R3, RES 332 OHM 1% 50PPM 1/2W, Vishay Dale [CMF332HFCT-ND] 2 - R4, RES 1.5K OHM 1% 50PPM 1/2W, Vishay Dale [CMF1.50KHFCT-ND] 0 - R5, for performance, use jumpers for these positions OR 2 - R5, for ultra low-impedance headphones like IEMs if the amplifier hisses with jumpers, RES 47.5 OHM 1% 50PPM 1/4W, Vishay Dale [CMF47.5QFCT-ND][/left]
Code:
Code:
[left][b]Power Section[/b] 1 - C1, CAP 470UF 35V ELECT FM RADIAL, Panasonic FM PSU capacitor [P12415-ND] 0 - C2, for performance, use jumpers for these positions OR 2 - C2, for safety, CAP POLYPROPYLENE .47UF 50V 1%, Panasonic ECQ input capacitors [P3888-ND] 1 - TLE2426CLP virtual ground rail splitter chip (TO-92) [296-1994-ND], or from [url=http://www.amb.org/shop/]amb[/url][/left]
Code:
Code:
[left][b]Op-amp[/b] 1 - IC SOCKET 8 PIN .300 GOLD, DIP-8 Socket [ED90032-ND] 1 or more - DIP-8 op-amp, your choice (P has better specs, PA is cheaper): Analog Devices AD823 [AD823AN-ND] Burr-Brown OPA2227[OPA2227P-ND or OPA2227PA-ND] Burr-Brown OPA2132[OPA2132P-ND or OPA2132PA-ND] Burr-Brown OPA2134[OPA2134P-ND or OPA2134PA-ND] Texas Instruments NE5532 [296-1410-5-ND or 296-7040-5-ND] Texas Instruments NE5534 [296-7042-5-ND or 296-7043-5-ND] Texas Instruments TLE2142 [296-10467-5-ND] If you elect to add decoupling capacitors on the bottom (see Extra), you can also try: National Semiconductor LM4562 [LM4562NA-ND] Burr-Brown OPA2228 [OPA2228P-ND or OPA2228PA-ND][/left]
Code:
Code:
[left][b]Extra[/b] 1 - Alps RK0971221Z05 pot and switch, 10KΩ, from [url=http://www.amb.org/shop/]amb[/url] 2 - STRAP BATT ECON 9V I STYLE 4"LD, 9V Battery Straps [232K-ND] 2 - CONN JACK STEREO R/A 3PIN 3.5MM, In-out jacks [CP1-3533-ND], or from [url=http://www.amb.org/shop/]amb[/url] 1 - LED 3MM BLUE DIFF, Blue LED [350-1560-ND] 1 - RES 10.0K OHM 1% 50PPM 1/2W, Vishay Dale resistor for LED [CMF10.0KHFCT-ND] (go with a lower-valued resistor if you want a brighter light) 1 - knob, search for 'aluminum knob .50' and filter your choices to 6mm diameter; I chose the ML series in black matte [226-4003-ND] [u]Decoupling[/u] 2 - Vishay/BC CAP .10UF 50V CERAMIC X7R 10%, Ceramic capacitors for decoupling [BC1084CT-ND] OR 1 - (pack of two) 0.1µF 50V Hi-Q Ceramic Disc Capacitor Pk/2, ceramic capacitors for decoupling, Radio Shack [[url=http://www.radioshack.com/product/index.jsp?productId=2062365]272-135[/url]][/left]
