Worth
- Feb 22, 2014
I'm looking to get a pair of closed headphones that are comfortable and have good isolation. My budget is preferably between $300 to $500, but I will stretch to $600 if there is a reason to do so. I listen to rock and metal the most, but there's nothing I really don't listen to some so I want whatever cans I get to be good all-rounders. I'm currently leaning towards either the Mad Dogs, Alpha Dogs, or Master and Dynamic Mh40s. Which of those would best suit me or is there something else I should consider instead?
Thanks, Worth
Thanks, Worth
