Traveller
- Jan 8, 2004
...The DFR on the other hand "consumes" 40mW on average. Not that the Mojo needs much more (35mW for 600ohms, 750mW for 8 ohms), so yeah, Chord Electronics could remove the battery - or offer a "bypass" option...
I think you have not counted for the power consumption of the Mojo's own processing circuitry as we've said Mojo has many times ( hundreds of times) the processing power of other Dacs. There is a cost in power usage for that processing so it would not be possible to remove the battery and still retain a comparable performance to that we currently enjoy.
John, thank you for you feedback, sir! Of course it is understood that the Mojo does a lot more number-crunching than an off-the-shelf DAC. The values I listed above are thus just what Mojo can deliver to the headphone jack(s).
Having said that... and taking into account the original poster's goal (to enjoy the Mojo without Mojo or laptop being plugged into the mains) I suggested that based on Mojo's trickle-charge consumption (once the battery is more or less fully charged) would most likely not demand the entire ~1Amp, normally consumed when charging an empty battery.
But the best bet is to put it all to the test. Unfortunately it's 2 A.M. here and I can't do a full test (say, 3hrs of listening), but I can at least see what Mojo is initially requesting current-wise, while in use. So I hooked up both USB ports to my laptop (power and audio), cranked up the Mojo and Foobar and I am playing music at a normal listening level, feeding my 100ohm Etymotic ER-4S. Here is the approx. constant consumption rate:
It is entirely possible this value will increase as time goes by but 30mins into the session and I still read the same 0.12Amps
@Rob Watts, you're up to bat...
