Xacxac
- Mar 15, 2015
I want to be able to mount Mojo to my Nexus 5 and at the same time don't want any adhesive on Mojo's shell
But there are some ways to mount them together without any residue. Bands, 3M..
A coupe of key scratches here and there. To be honest, it is useless. Don't even bother, spend your money on a dinner much better. Unless you live in a cold place, covering mojo in summer is a really bad idea. It will be cooked like a steak inside your pocket .
Personally, I went with the Pelican 1020 case. It is a very protective case. The main disadvantage of this solution is that you cannot use mojo in your packet. If that is ok with you, then go for it .
Yeah but can put the Mojo say ten minutes in your pocket then take it out hold it while walking then put it in for awhile. The Mojo really cools down really fast once out of the pocket.
I don't think heat is a problem with mojo. It gets warm but not hot even inside pocket.
Usually I put mojo in a pocket and my phone in another pocket, an USB cable run through belt loop. I find this way works better because I use my phone a lot and none RF interference. For storage I use pelican 1020.
As cosmetic damage, I'm not that afraid. I take care of my mojo quite well; has dropped twice, no scratch. But then, I have to admit that mojo isn't built as perfect as apple products. My unit's top and bottom piece are a little bit misaligned.
