CHORD ELECTRONICS DAVE
May 12, 2016 at 1:22 PM Post #2,926 of 25,909
MQA seeks to accomplish 2 things:
1.  Correct for ringing artifacts introduced by the ADC that MQA believes have a negative impact on time resolution.
2.  Serve as a file wrapper that results in a smaller file size when encapsulated but then returns the original lossless file when the encapsulation is removed.  The file remains encapsulated during streaming allowing for the delivery of high-resolution files (up to 24/352.8) without requiring large amounts of bandwidth.  The potential benefit is that you now have the ability to stream DXD-sized files (potentially hundreds of MBs in size) through your iPhone with a simple 4G cellular connection.  During playback, however, the file returns to its normal size and so what the DAC ends up seeing is the original lossless file.
#2 would be the only potential benefit for users of the DAVE (or your Nagra HD, since this is a DAC that upsamples to DSD).
3. It authenticates, meaning: buy an MQA compliant DAC if you want to access the high resolution hidden "file". Bob Stuart has admitted that he wanted to offer the experience of high resolution while keeping the original high resolution file off the audiences' hands. This new "revolutionary" format is already dead.
May 12, 2016 at 1:35 PM Post #2,927 of 25,909
I need them close so I can A/B with them over the next month.
Tonight, I listen to 1980's J-pop.  Some 明菜から… by Akina Nakamori.  Her strong deep voice sings through the DAVE making me remember how my LPs sounded on my Technics turntable back in college.  Of course with the DAVE, I am hearing far more details than those small Spica speakers I had then.  Scary details like the singer licking her lips and sometimes the breathing gets outta hand.
I know what you mean, I jumped out of my chair a couple of times, Dave brings out a lot of details, but with mR, wow, scary. LoL
May 12, 2016 at 1:49 PM Post #2,928 of 25,909
Been using the Mapleshade  14 footer toslink with Macbook Pro Retina and DAVE for 6 hours using iTunes, Audirvana and Media Center.
1. Using iTunes
All playable iTunes tracks, up to 192k are playable but shown on the DAVE as "44.1k"
2. Using both Audirvana and JRiver Media Center
I could not find "Optical" in the Preference or options, so neither player works with Toslink.  (since, I tried another optical cable, the same results)
3. Strange thing when I tried Optical-2 input on DAVE with Audirvana
the display flashes 176k for many seconds.  Since, I now get a steady "no input"
Summary:  ITunes plays with Toslink on DAVE, but all tracks at 44.1k
Cannot get Audirvana or Media Center to work with Toslink.
@Rob Watts
Rob, What do you suggest?
Thanks
Paul
May 12, 2016 at 2:05 PM Post #2,929 of 25,909
Well, Roy, even with less than ten hours on the microRendu, it seems you have answered, to your satisfaction, the question of whether DAVE is sensitive to various source/server components. Thanks for sharing your impressions and comparisons. And for $640, the mR would appear to be a no-brainer purchase, with extra $ going to a nice power supply. At some point during the next month, I'll get to listen to a friend's mR in my system and will share any insights. Assuming I like what I hear, I'll probably wait until John Swensen's "mystery" power supply comes out later this summer before taking the plunge.
I maintain the opinion that all sources (at least all sources I have tried) sound very good with the DAVE and so to this extent, the DAVE is pretty well immune to "bad" sources but there are exceptional sources that can and do sound better and I am convinced that this is not merely a bit-perfect issue.  I don't believe it's a jitter issue as I have convinced myself the DAVE truly is immune to source jitter (i.e. my Oppo/Tidal example is proof of this for me) and so this leaves me to believe that source RF is the issue despite the DAVE's galvanic isolation,  Rob has suggested RF is difficult to completely mitigate against and compares it to a "fungus" that can't be completely eradicated.  The mR uses 10 regulators in its design from it's ethernet PHY to its USB hub, with each regulator providing some level of isolation and so as each of the components within the mR create their own RF that adds pollution to the signal, there are enough regulators in the chain to mitigate it as it is created.  The other supporting evidence for RF being the culprit is that a really good power supply (defined by John Swenson as one with very low output impedance) is supposed to make a significant difference with SQ.  I made an inquiry on the CA forum why this makes a difference but I got no response.  Paul Hynes, who will be building my power supply explained it well, however.  The lower the output impedance of a power supply (in the ideal world, it would be zero), the higher the PSRR (power supply rejection ratio) will be and in the ideal world, PSRR would be infinity.  PSRR is a measure of a power supply's immunity to the powered circuit that feeds it and an infinite PSRR would result in complete isolation to that circuit regardless of how dirty that circuit may be.  Because an infinite PSRR is not possible, no power supply can be completely isolated against the powered circuit but certainly, this is what you strive to achieve.  Again, this speaks to RF in the supply line as being the problem.
Considering John Swenson's mystery power supply is supposed to cost less than $500, this will probably be the best value proposition although how will it stack up against the best solutions?Even John doesn't know since he doesn't yet have a working prototype.
As of this morning, the mR continues to improve.
May 12, 2016 at 3:02 PM Post #2,930 of 25,909
1. Using iTunes
@Rob Watts
Thanks
Paul
Paul, I don't believe these are DAVE issues.  iTunes is capable of up to 24/96 playback on a Mac but you have to configure this in Audio MIDI (found in your Utilities folder).  Unless you change the default, all your high res files will be down sampled to 16/44.  With regards to Audirvana, I can't comment because I don't use this software but if you can play music through toslink on iTunes, then you know you at least have a viable optical connection with the DAVE which would suggest this is an Audirvana problem.  It's probably a configuration setting you will have to change.
May 12, 2016 at 3:07 PM Post #2,931 of 25,909
Thanks Roy.  I am going 30 hours now without sleep.  Sorry if I am not careful with my wordimg.
I suspect my DAVE (now with pretty legs) is working perfectly and my issues is with supporting software.
I will continue to tinker.
BTW Roy, do you leave the display on always on DAVE?  Any fear of burn-in?
The bottom of DAVE gets warmer than the top. I realize this with the stand.  So, the stand may help with sound.
(hint hint)
Paul
May 12, 2016 at 3:26 PM Post #2,932 of 25,909
(hint hint)
Paul
It's a great looking stand.  I would happily buy it for that reason alone but I am happy with what I have.
I use setting #4 where the screen blanks after a few seconds but I don't know if this matters as far as longevity.  LCD/LED panels aren't prone to image "burn-in" like plasma and OLED displays are.  The typical MTBF (mean time between failure) of modern LCDs is supposed to be well over 50,000 hours.  The entire chassis of the DAVE was designed to serve as a heat sink and so it is expected to get warm and as long as heat can dissipate at any point from the chassis, I think you're fine.  Heat output from the DAVE has never been an issue for me and at no point is mine hot to the touch.  The DAVE comes with a 5-year warranty which is pretty good assurance.
As far as helping SQ, many believe components sound best warm (approaching hot) which is why many amp makers advocate you keep your solid state amps left on all the time so they're ready to go when you are.
May 12, 2016 at 6:44 PM Post #2,933 of 25,909
Just received my ship notice for the Sonore Signature series power supply. I'll be sure to leave some impressions after I have a chance to listen next week.
May 13, 2016 at 2:43 AM Post #2,934 of 25,909
Agreed that jitter is not an issue with Dave; nor with any of my other DAC's. We can see this on the measured performance with Dave, as there simply are not any artefacts:
The reason why I am so confident that jitter is a non issue is because of a number of things:
1. USB operation gets its timing from the local Dave oscillator, and incoming data gets re-locked to the local clock.
2. When I add 2 uS (that's 2,000,000 pS of jitter) to the data input from the AP using optical or coax I measure absolutely no change whatsoever. Now that on its own is not enough, as I have had situations before where unmeasurable effects are audible - but not concerning jitter. I have always been able to hear an effect then measure it.
3. One way that an incoming data can effect the SQ is down to ground plane noise, and in the past this used to be a big issue, both in measurement and SQ. And it's technically possible that ground plane and power supply noise can affect the SQ (I have seen this many times before). But in the case of my modern DAC's I have been able to eliminate this issue by a combination of local RF filtering on power supplies, double layer ground planing,use of efficient local SMPS, and power efficient FPGA's, plus careful layout. Now this issue used to be a nightmare, particularly with the FPGA, when my DSP cores used power hungry FPGA fabric. I would have to construct a DSP core by creating my own multipliers (today I use dedicated FPFA resources that are extremely power efficient), and every time a new place and route occurred, I would get different sound and different measurements. Today this situation never happens for lots of reasons - better design of the ground planes, better local RF filtering, better quality of RF filters, and dramatically lower signal induced noise (actually this is thousands of times lower than ten years ago) from the FPGA. Today, different place and routes show no SQ changes, or measured changes. What I am alluding to here is that the noise from a jittery source can't upset the sound quality through induced noise, as it is now (as far as I can tell) completely isolated - its also one of the benefits of the USB galvanic isolation in that the USB processor gnd and PSU noise is isolated from Dave.
4. Pulse Array DAC is innately jitter insensitive. What is not readily appreciated is that different DAC architectures have very different sensitivity to clock jitter. DSD is horribly sensitive to jitter, R2R DAC's are very sensitive, but pulse array is innately insensitive. The reason for this is that signal switching activity is completely signal independent - it switches in exactly same way whether its reproducing 0 of fully positive or negative. Because of this, when I get some clock jitter, it only creates a fixed noise. Now one of the really cool things that happens today is that PC resources and simulation tools are so good today, in that I can write a simulation, and add some jitter to the simulation, then measure the results using an FFT. From this, I can see exactly what jitter and only jitter does - and this technique has revealed a few surprises. But what it has done is proven that adding random jitter creates zero signal correlated effects to pulse array - no distortion, noise floor modulation at all - just an insignificant level of unvarying random noise. This does not happen with other DAC architectures, as you will then get significant noise floor modulation, distortion and noise shaper related noise. This is because with the other types of DACs, the switching activity is signal related. So DSD has maximum switching reproducing zero, and no switching at 100% modulation. R2R has no activity for zero, but considerable switching activity when the signal changes.
As to RF noise yes it is like a fungal infection. In the mid 80's, when I began to appreciate the importance of RF noise, I created a RF noise mains filter, in order to eliminate the SQ changes that mains cable was making. This ended up being a scary design - a cascade of inductors and capacitors, with filtering from 100 kHz to over 1GHz. I even had to make my own PTFE air cored inductors to get the performance I needed. But it worked - you could absolutely not hear the effects of different mains cable before the filter, but I had to use insane levels of filtering.
So I know how crazily sensitive things are to RF noise, which is why I can't say for absolute certainty that RF noise from Dave or from the sources may or may not affect your system - simply as most power amplifiers are very RF sensitive. So it really is a case of YMWV. But I would like to make a few suggestions:
1. PSU design - as far as impedance is concerned, forget it in relation to RF noise. Now impedance is an important issue, but it has no bearing on RF noise. It can be important in that signal currents will cause distortion due to the OP impedance. That's why the reference power supply for the pulse array is less than 0.0005 ohms for each and every flip flop as that is an important source of distortion. But it has no bearing on RF noise, that is another issue. But today, filtering within the DAC can be done to a very high level of performance with modern SMD capacitors, inductors and ferrite beads.
2. Source - my advice with Dave is to use a source that is convenient for you. So far, in my system - and again YMMV, I have failed to hear any significant difference between different sources.
3. RF noise in terms of SQ. When you reduce RF noise, things sound softer and warmer and smoother. Bass is rounder with less slam and impact. Now if it is a bit perfect input source you are making changes, the only thing that can make a difference to the SQ is RF noise, so go for the warmer and softer sound - as that is the most transparent - even if it sounds too smooth! If it is too soft, don't worry - it is not a problem - you just need to then improve transparency elsewhere in your system - such as better cables, changing where the loudspeakers are sited, different HP, EQ etc. One of the profound problems we have with audio is that making fundamental improvements may affect the balance of the system, so it is less optimum. The trick is to understand when you have indeed made a fundamental improvement but that gives you an unbalanced sound then make other changes in your system to restore the overall balance.
Happy listening, Rob
May 13, 2016 at 3:13 AM Post #2,935 of 25,909
Thank you, Rob!  Are you suggesting that the distortion produced by the source or its power supply can affect the DAVE?  Could this be the reason for the sound quality differences one might hear between two sources that each have bit-perfect output?  Clearly, the SQ differences I am hearing are not just improved smoothness but improved dynamics and a much more open soundstage.  Once again, I want to stress that I have not heard a source sound badly with the DAVE and so this is quite an accomplishment but I have done blind testing this evening just to be sure I'm not imagining things and 100% of the time (5/5 tries), I am correctly picking out one source over the other.
May 13, 2016 at 3:31 AM Post #2,936 of 25,909
What a brilliant and revealing post. Learning so much here.
Rob you mentioned earlier, switching power regulators seemed to work better than linear power regulators, and you had figured out why. It would be great to know...
May 13, 2016 at 3:49 AM Post #2,937 of 25,909
Back to using AQ Diamond USB.  Did not find much difference using Curious Cables plus Regen.
Paul
May 13, 2016 at 3:52 AM Post #2,938 of 25,909
I would be surprised if Dave was sensitive to RF noise from the source via the mains - but that's not saying it isn't 100%. I don't think it is a significant issue, as I travel around with Dave, and via headphones I hear no difference - and the mains quality varies enormously from building to building, country to country, and Dave via headphones always sounds the same. I can remember my system varying all the time, with best sound at 2am with all the lights off - this was before I understood how important RF noise actually was. Now, with extensive RF filtering, I do not get these changes. But I had planned to listen to different mains cables, but have decided to make some up myself, as the available cables I am not 100% happy with from a RF POV.
The actual distortion mechanism is noise floor modulation - random RF noise gets into the analogue electronics, and at RF frequency things are very non-linear. Then you get intermodulation distortion with the audio signal and the random RF noise, giving you random intermodulation products that is in the audio bandwidth. So noise pumps up and down with the audio signal, making it sound harder and brighter. Unfortunately, the brain is very sensitive to this effect.
When you were doing your listening, was this with Dave on its own via headphones?
Cheers Rob
May 13, 2016 at 4:55 AM Post #2,939 of 25,909
"If it is too soft, don't worry - it is not a problem - you just need to then improve transparency elsewhere in your system - such as better cables, changing where the loudspeakers are sited, different HP, EQ etc. One of the profound problems we have with audio is that making fundamental improvements may affect the balance of the system, so it is less optimum. The trick is to understand when you have indeed made a fundamental improvement but that gives you an unbalanced sound then make other changes in your system to restore the overall balance."
This is good advice Rob I think, particularly with speaker setup. I wonder how many systems out there are seriously underperforming simply due to bad speaker setup. I would say that with Dave the sound is complimented by very focussed tweeters. Wide dispersion tweeters hide the incredible accuracy of Dave, even modern ones like Kef's Uni driver. I had a pair of their previous Reference speakers to compare with the current version and imo Kef have taken a step backward in class leading accuracy. Easy to setup the latest speakers yes but at the cost of separation. I currently use the Sonus Faber Olympica and that tweeter is like a laser beam by comparison and setup is accurate to about 1/64". It is worth taking the time to get it right though in order to get the best out of Dave. to dial them in I use acoustic tracks particularly where the acoustic instrument has been panned wide as it is easier to hear when you have dialled in the reflection. I am sure there are many other very focused tweeters out there, not to mention the option of electrostatics. This for me though is one of the standout features of Dave in that you can have digital sound focused like never before and it isn't edgy. In the old days people would look to match things in order to blunt the focus and go easy on the ears. No longer necessary imo.
Edit: That's 64th of inch on front spike adjustment
May 13, 2016 at 7:21 AM Post #2,940 of 25,909
Yes, it was a big surprise to me. I have been resistant to using switchers inside DAC's, for a long time, as after all everybody knows linear is better, due to lower RF noise.
But with the Hugo design, I had to use switchers extensively, due to efficiency and battery life. Today one can get very high speed > 1MHz very efficient switchers, in tiny packages. And listening to it against the linear regulators gave a big improvement in SQ - a lot smoother and warmer. The act of using a switcher forces you to use more RF filters, and that on its own improves the sound quality. Moreover, the power efficiency benefits also have measurable SQ improvements too - with Dave the FPGA core current is 5A - having 5A at 5V is a lot of weakly signal correlated current floating around from a linear supply. But using a switcher means it is now only 1A and because of the activity of the inductors, input and output filters, is much less signal correlated, and so has less ability to corrupt the analogue output stages, and then gives measurable improvements. I do tests to assess ground plane noise, and before there were significant measurable problems, now I get nothing.
I must say these benefits was a big surprise. It teaches us an important lesson - thinking something must be better because of XYZ is often a mistake. You have to do the work, do very careful listening tests, then come to a conclusion.
Rob
