Sonic77
- Dec 12, 2011
Haahaa can you imagine. Many DACs enter one dac leaves. Bunch of designers with their DACs out for blood. Rob would need to redesign the Dave to be longer and more to a point.
It would go something like this
@ecwl, Hq player is a bit difficult to set. can you please give the link for the best sq setting in Hq player ? i want to compare through mojo , an unaltered CD quality stream via foobar and upsampled stream from Hq player !
Go to www.soundgalleries.com and then click on "Articles."
This just got in! Will be doing an extensive review for a local magazine in the upcoming month. Running in for a couple of weeks right now with Mass Kobo 394 and HEK and will be hooking this up to my reference 2 ch. system with Aurender W20 / Esoteric K01X / Gryphon / Magnepan 20.7 after testing it with various headphones. Stay tuned....
Except the article recommended a DSD setting which would be fine for a "native" DSD DAC but suboptimal for Chord Mojo according to the Computer Audiophile forum discussion. So we are back to what is the best PCM setting. According to the HQPlayer website (without downloading the program), there are
Resampling filters:
- 8 linear phase
- 5 minimum phase
- 3 impulse optimal
- 2 closed form
Dithers and noise-shapers:
- 4 dithers
- 4 noise shapers
Moreover, each of the filters and noise-shapers have their own settings. Don't get me wrong, I strongly suspect HQPlayer is great. But mainly for the tweakers... It's almost like asking Rob Watts to let us run a computer program so that we can sync with the Chord DAVE and tweak the FPGA so that we can choose our own WTA algorithm and noise shaper.
Remember to take out your Gryphon Pandora preamplifier when testing out the Chord DAVE and use the power cable for the Pandora for the DAVE. Unless the power cables are the same. I think it'll be interesting for you.
And I wonder if you can help rayleemw find a local dealer in Hong Kong for the Chord DAVE. Heck, invite the guy over...
Congrats! But I wonder: What has the Mass Kobo 394 to do with running in (DAVE or its headphone output?) or driving the HE1000?
I'm sure some folks would be interested in whether you find that the DAVE is sensitive to the Aurender W20. In other words, could you compare the DAVE with both the W20 and a stock computer and note what differences, if any, you find?
I think I understand it. Perfect low-pass filtering means infinite Q means infinite ringing. Infinite Q means that just the resonance frequency itself is affected by the ringing, every frequency below is perfectly reproduced in the time domain (although that's impossible to measure). Any (real-world) low-pass filter with a finite Q factor will introduce transient corruption below the filter frequency to some degree. Right?
So DAVE approaches an infinite Q factor? I've seen measuring data indicating –0.04 dB at 20 kHz, which is pretty good.
However, in the real (non-DAVE) world avoiding pre-ringing may be beneficial, at least the corresponding filter 3 on my Corda Symphony sounded special to my ears (sometimes I considered it the best).
The main effect I noticed with Hugo and Mojo (and hopefully Dave sometime soon if I can audition this in Dubai), is the free flow of music.
There seems to be no stress of listening to music on Hugo and Mojo, it just flows, like analog recordings and live music.
Whatever the engineering is, at the end of the day, a DAC has to perform musically, and I am very happy with musical performance of Hugo and Mojo.
Other than Piano notes being very clear, I am also noticing that drums have that impact, I guess the starting and ending of notes is clear and not blurred anymore so much easier to hear and enjoy snare drums.
Total agreed with you jaZZDAVE offers even much more of this very quality.
I haven't thought of it that way - thinking in terms of Q - but it makes sense and is a good way of looking at it.
But the first stage WTA filter is way better than 0.04dB - that's a symptom of other filters (notably the analogue ones). Looking at the results from the actual filter used in the FPGA (quantized coefficients) the frequency response is +0.000003 dB at 23 kHz (48 KHz sample rate). Its still within +/- 0.3 dB at 23.970 kHz - so that is only 30 Hz away from the critical FS/2 point.
I do not think people appreciate how sophisticated Dave's DSP actually is; with 166 DSP cores running in parallel, it works out at a staggering 0.1 Tera instructions per second (TIPS) and that's just the WTA filtering - the further interpolation, filtering and noise shaping is getting on for another 0.1 TIPS.
But the point I am trying to make is that impulse response is not a good way of looking at filter performance, as we are talking about using an illegal non bandwidth limited signal. And people make the mistake that a small amount of ringing is a good thing and is evidence of good time domain performance - when it is not. When I talk about time domain performance I am talking about how well the filter reconstructs the timing of the original and you can have a low amount of ringing that has quite good timing, against a longer ringing filter that is actually worse timing. Of course, an infinite amount of ringing with an ideal sinc response will perfectly reproduce a bandwidth limited signal with no changes whatsoever - and this is what high end audio is supposed to be about. I can gain a much more accurate predictor of sound quality just looking at the total output using 0 dBFS random noise. In short talking about ringing is a red herring.
Rob
Yes, but DAVE requires much larger pockets, in more ways than one!
