Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Would somebody kindly explain how we should read following specification of Dave and would kindly explain how good it is?
Dynamic range at -60 dBFS 1kHz -127 dBA A wt
I was told from one of our hifi forum member that this specification is not so good when compared with other DACs and was wondering if that was true.
But am not so technically strong and would appreciate if someone would provide easy-to-understand explanation about it. Thanks.
People get confused with DR - somebody once said that Dave was poor compared to some silly DAC - they claimed 160dB - it turned out that the DAC measurement was the noise floor. Dave noise floor is -180 dB and has zero measurable noise floor modulation. Here are some recent measurements:
No other DAC comes anywhere close to Dave's measured performance. As too DAC dynamic range, its a pretty meaningless number - it just tells you the residual hiss level. What is more important is noise floor modulation, of which Dave has none, and small signal distortion, which again Dave has none.
Rob
