007noob007
- Oct 12, 2011
i live in israel, so we dont have that many headphones...
here are my option-
akg
[size=10pt](if you are intrested https://www.youtube.com/watch?v=Ron17xFNBf0, http://www.youtube.com/watch?v=WmX_GgozpQs are two very different new song my friend showed me)[/size]
[size=10pt] [/size]
[size=10pt]use- i will mostly listen to them on the bus ( I have fiio e6 if it helps) and in the car (maybe a bit to watch movies at home, and listening a bit at home)[/size]
[size=10pt] [/size]
[size=10pt]More-[/size]
[size=10pt]1) If possible a changeable/removable (this is what get broken most of the time, and i wish to be able to change the cable when it is broken)[/size]
[size=10pt]2) Comfortable for long use[/size]
[size=10pt]3) Looking "ok" not too important, but will be a nice bonus[/size]
[size=10pt]4) if possible noise canceling (as much as posible)[/size]
[size=10pt]5) 5)[/size][size=13.5pt]Good music quality, good base, and Good noise separation are the most impotent stuff (noise separation is crucial)[/size]
here are my option-
Shure SRH-750-DJ
akg q460
akg k181akg
K450
skullcandy aviator
akg
K451 (what is the difference from akg k450)
Shure SRH440-A
[size=10pt]music- I listen to all kinds of music: rock, Irish music, jazz classical, hip hop (just a bit), Japanese music and a lot of just weird stuff [/size][size=10pt](if you are intrested https://www.youtube.com/watch?v=Ron17xFNBf0, http://www.youtube.com/watch?v=WmX_GgozpQs are two very different new song my friend showed me)[/size]
[size=10pt] [/size]
[size=10pt] [/size]
only from the list! please, trest me i have no other option!
h4mm3r 0f th0r
- Sep 14, 2011
you might not have many options there... but can't you import??
machoboy
- Aug 20, 2012
For diverse genres and good "seperation" (really, no headphone has good separation, but I know what you mean), the Shure 440s are probably your safest bet.
007noob007
- Oct 12, 2011
no i cant import
007noob007
- Oct 12, 2011
they do sound like the best option, but from what i heard there are not that confertble, and not that good looking. is that true?
streetdragon
- Dec 29, 2011
there, a picture of them on a head
007noob007
- Oct 12, 2011
[size=10pt]not to bad, i had the akg k240 mkii and they were a bit to clumsy for me... so i am not looking for the "big" headphones[/size]
[size=10pt]are they any competition to the akg 240?[/size]
[size=10pt][/size]
are they confertble? are they duruble?
[size=10pt][/size]
- Feb 1, 2011
+1 for SRH440
Review on blog in my signature.
007noob007
- Oct 12, 2011
are they not to big and unconfertble (for my use... bus and long listening)
+1 for SRH440
- Feb 1, 2011
Not that big, comfort is easily fixed with a little bit of foam on the top of the headband. Sound is excellent
007noob007
- Oct 12, 2011
if you tried the akg k240.
are they better qualty then them?
007noob007
- Oct 12, 2011
are the SRH440 better then akg 240 mkii?
007noob007
- Oct 12, 2011
bump
007noob007
- Oct 12, 2011
bump
GREQ
You won't want to use the K240 on the bus, as they're semi-open and better suited to home listening... also they're quite big and look a bit silly outdoors.
But they do sound good and are very durable.
