Skullophile
- Dec 18, 2012
We gotta get one of the usual suspects to review the Carrot Titta One!!!!!!!!!!!!!!
That's my resolution!
My new years resolution? To get more people to try the Bette (ivalux) 10mm METAL earphone.
I may have mentioned these before once or twice.
Yeah they are THAT good.
HAPPY NEW YEARS!!!!!
TWIN
I don't know anything about DACs and Amps so I'm going to ask you guys!
1. I play my music from my Dell M6500 laptop and Nexus 6 phone to both IEMs and Headphones. Will a DAC/AMP improve the sound quality? If so, any recommendations for a portable one less than $150?
2. If I don't need a DAC, any recommendations for amp less than $150?
1) It is very subjective. But if you have a high end IEM/headphone or IEM that you are use to it. You maybe notice a slight different. But as you move upward to higher end gear. It may change dramatically. Still it depends on your ear that's why it is very subjective.
Fiio E18? Not sure about the current price.
2)Every device have a DAC and amp. But mobile phone and laptop usually is build into an SOC (System on cheap) to save space for putting in other component. Amp is only use to amplify the signal and also provide stable/better power to feed the Headphone or IEM.
I maybe wrong, but do correct me!
Heck yes. 5.8 mm? I'm in!
hey B9, have you managed to try this one yet?
Well, ONE of my resolutions this year, NOT to buy so many earphones, just went Down in Flames.... I'm SO ashamed. Didn't even make it 12 Hours....
I just ran across these gems. anyone know anything about them? 10Hz-20kHz, 9mm driver, interchangeable rear filters. for $15?
Even with the flat wire I COULD NOT RESIST:
http://www.amazon.com/dp/B0176XT9Z0/ref=twister_B0178I3JOK?_encoding=UTF8&psc=1
Got them in Black but I WAS tempted by the Green ones.
Get this: out of 1,739 REVIEWS 1,355 are 5 Star!!!!
If it's any good, that will be a plus.
TWIN
