Hello guys!
I'm coming to you now with a little research about my very cheap budget IEMs. Everybody needs a totally cheap pair of phones, even if you don't want to spend much, can't spend that much on it, or just want a unit that you don't want to pamper every time, just grab and put in your pocket/bag.
So: I'm a newbie, newer had expensive audio gear, but I truly feel that the quality what I'm looking for is much more than these ones. :etysmile:
Source: Samsung Galaxy Ace 3 with Custom 5.0 rom
App: Jetaudio Plus
EQ: Flat with bass boost below 200hz sections. Moderate tweaks for better bass and wider soundstage as well.
Music: EDM.
State of IEMs: 20-40 hrs of burn-in.
Here are my results. You can see my color-based opinion on their value2price ratios as well (red means worst, green means best)
So, let's go from the bottom to the top.
6. VJJB K1 - DIY upgrade(?) IEM from Sidy DM2. Out of the box, pretty bad. Cable looks durable with the twisted style, but feels flimsy, too long part after the Y-splitter for me (though it can be a plus when wearing cables behind neck.)
Ergonomics is pretty bad, nozzle is short in an odd way, hard to find and fit the proper eartips, lots of them falling off.
Sound: TONS OF BASS. That's why it is muddy. There are much better choices under 10 dollars.
5. KZ R1 - Super cheap, super comfortable, super easy to put on or just change tips. Very tiny earpieces. Good for sport or just laying around and watching some movies.
Has durable strain relief at the L-shaped jack, even at earpieces. At the Y-splitter tho there are pretty much none. Cables are little thin from this crucial part, but you can buy 3 of them if you really like them. They don't seem too bad afterall.
Sound: Big step up from K1. Better controlled bass, better mids and highs. It's "okay", for 4 dollars? It's pretty much good, even considering the whole package.
Extra: Very easy to drive! Even the lowest budget portable player (small ones without display for example) could easily drive these IEMs. Listening to it on quite low volume with my phone.
4. KZ DT3 - Star of KZ thread, but I'm not that impressed. It has potential and has a bit cleaner sound than R1, but I guess, it would need more burn in. KZ R1 is more "coherent",There are some problems with tip rolling here as well, but nothing too serious.
Comes with straight jack, thick enough, or I would say kinda sturdy cables and plastic, lightweight earpieces. They are on the longer side (like Duoza), but nothing serious.
I feel like they can be better with more burn-in, that's why the higher rank.
3. Awei Q9 - My favourite here. Little brother of T1E maybe? -
Highly recommended.
Sounds quite good even out of the box. Has nice wooden earpieces and fibre-covered cable, but quite thin cables. Strain relief is average on the critical parts. They feel a bit fragile..
As mentioned, has a wooden housing, but it's quite big! I dont have small ears but the bulk of the IEMs makes inserting a bit uncomfortable - the rim of the earpiece touches my inner ear. Nothing too serious, but certainly not a partner for long listening sessions. Deep insertion is not really supported because of chunky housing, unlike KZ R1.
Sound: Big step up from DT3. Has plenty of bass, pretty well controlled, and not overpowering mids and highs. For 4 dollars? Excellent! Much less V-shaped than previous phones, better overall clarity.. king of 5 dollar IEMs for me.
2. Piston 2 & EDSE
-- EDSE: Incredible build quality. Super sturdy cable. Forward sound - full bass, but mids are definitely there and has quite a lot "treble energy" -> very versatile IEM. Sometimes can be harsh, but more burning/better tips/EQ surely can help. Has great potential, great cable and strain relieves, considering that it has an oddly long nozzle (makes eartips sit a bit weird on them), it is still an incredible value for it's price. (Cable twists quite easily, but easy to untangle, due to its thick, good quality)
-- Piston: The other side of the coin. Has much bass, has good sub-bass rumble, good build quality, remote control, mics, and OK mids and treble, tho it is lagging behind EDSE in terms of regions above bass. BUT it is very smooth, easy to listen for longer times, and your ears get used to it's sound pretty easily. With it's semi-open construction it's not the best for commuting.
1. T1E - much more coherent sound than any of these below, can't wonder why are they a bit more expensive. Has good mids, sparkling treble, good bass. But have to point out a very important thing:
These are not basshead IEMs! I even find it a bit lacking in terms of bass.. (I <3 subbass)
Build quality is on par with EDSE I would say, but large housing can cause problems, tho maybe not on the levels of Awei q9. They need totally different settings in your player, than previous phones.
Getting proper tip and seal.. very difficult. Tried lunashops medium bore (heir style) tips in M and L sizes, several wide bore tips, now using Stock L sized whirlwinds on my right, general black wide bore tips (L sized, from lunashops as well) on my left. I feel like it could be better.. guys mentioning Piston L sized tips, too bad I dumped them when purchasing my Pistons..
But: the wider the bore, the better the sound as I see. JVC spiral dots would be interesting on them. They are really wide as I know.
So, that's it guys. Hope I could help some of you
