tourmaline
- Nov 10, 2003
I can compare between elektrostats and dynamic headphones.
i think quite the opposite of Nik.
i owned a top stax rig and i was always missing something in the mid/low bass section.
the bass didn't go as deep as the dynamic cans. the bass is maybe a bit more detailed as the dynamic phones, but i felt it was a bit "to" dry sounding(not natural to me). using tubes will make it slightly worse either. since most of the tube gear doesn't have the punch of solid state amps.
one big disadvantage of the elektrostats is that they wear!
they slowly deteriorate in time. so, even as you listen, it might not be as good as it was some months ago.
the big difference between the two is:
elektrostats: very detailed, neutral, can be to dry sounding.
dynamic: more natural, more intimate, maybe less detailed, more drive.
well, that's what i think of it.
good cans are good cans whether they are open, closed or elektrostats.
Nik:
you can always experiment with the interlinks. they can dramatically change the sound of the system.
alot of people seem to have most problems with silver cables.
it needs carefully tweeking. alot of people use silver and copper in their rigs, to soften the silver cable a bit. most silver cables can sound agressive. especially in the low and high end of the spectrum.
Nik:
