Will need confirmation from Cayin regarding Coax. N5 has 3 outputs on the top, 3.5mm and 2.5mm for HO and one other. I'm pretty sure that one is LO and perhaps it's shared with Coax?
I won't consider any further DAP (including Fiio x5ii that I really liked) until there is a matching coax cable available as good as the current DX90 one supplied free by iBasso. If DAP manufacturers want their coax socket easily usable, why put on a non-standard hybrid socket without supplying a one-piece cable? Or better two! One for portable DAC use (male rca) and one for connecting to 75ohm coax cable for HiFi connection (female rca).
N5 have LO.PO. balance and coaxial output, which will share an LO and coaxial interface through the menu function selection switch, four outputs can not take effect at the same time.
N5 also be used for DAC or digital interface to use. Support decoding USB transmission Dop, and we are still trying to form Dop coaxial output(DSD64), which includes N6 included, if in the end we do that, we can through a firmware to update.
AKM4490 is a dual channel DAC, so using one is like having a double, just depends on how it was implemented, in single or dual mode. Cayin hasn't confirmed that yet though I'm hoping for dual.
