aos
May one day solve the Mystery of the Whoosh
- Jun 21, 2001
ppl, you should look at the latest voltage regulators. The classic 3-pin 1970's designs are way inferior to everything being out now. I spend tons of time over the last months looking at them for my DAC. There are references out there which have all the key parameters - load, line, temperature, dropout and noise - **SEVERAL** orders of magnitude better than those old regulators. For example, just couple of hours ago I placed an order for Analog's ADP3303-xxx voltage regulators. Don't knock out them just yet. Besides, what are you going to use in a discrete regulator to give you reference voltage? A LT1027/LT1036 or another one of many of voltage references made by LT, AD, NS, TI and others. 1ppm temp coefficients, less than 1uV p-p noise, virtually independent of line/load, ultra high initial precision etc...
However, I would like to look at your discrete regulator. Not for the portable DAC, but for the stationary it's always good to have the option. The one I used before (shunt reg) has only a resistor in the rail path and MOSFET as parallel regulating element, and opamp is used to compare the voltages. I suppose opamp can be replaced with a Darlington transistor or something, but you say you have your own design which has low temperature drift, so I'd love to see that too.
