Calling All "Vintage" Integrated/Receiver Owners
May 29, 2015 at 1:37 PM Post #14,491 of 19,143
Wow, that Sherwood certainly has a beautiful layout inside. I'd love to fit a clear glass top to it and watch the tubes glow.
May 30, 2015 at 10:57 PM Post #14,495 of 19,143
Just curious, what type of speaker terminals does evyerone use with their vintage amp? What are the best options?
To date, I kept all binding posts original on my vintage lovelies. I may elect to upgrade the posts on the Sansui in the future with higher quality metal and perhaps a 5-way scheme.
Will look at other's answers with interest.
May 31, 2015 at 1:32 AM Post #14,496 of 19,143
Quite frankly, this is the most PITA alike thing in vintage gear.
The terminals on my beloved Technics gear is - ahem - subpar (if we are polite about it ).
Rhey can be replaced - but you will look far and wide before you will find "something/anything" that can phisicaly fit
the space/volume available - and it will result in VERY tight placement and not exactly user friendly changing the speaker/headphone cables. The biggest problem is in making the isolation "washer/plate" that allows for safe operation both in mechanical and electrical sense. It has to fill any void between the original cut-out on the back plate and the new binding post's contact - in order to ascertain the above requirement.
And that is strictly speaking - LOTS of work. Finding the plastic of EXACTLY the thickness required ( it has to match the thickness of the original back plate, only a bit thinner in order to allow tightly screwing the new binding post in the place ) and shaping this "washer/plate" in exact shape is no picnic.
But it IS worth the trouble. Although cramped and not user friendly, it would allow for a much better contact than on the original gear.
May 31, 2015 at 3:06 AM Post #14,497 of 19,143
I like the 12awg bolt/banana type that are on some of the totl sony models. They're chrome plated bolts with a dual hole scheme to allow the speaker wire to be tightened on with a bolt or accept banana plugs. All the other terminals I've seen usually leave a bit to be desired :/
May 31, 2015 at 11:47 AM Post #14,498 of 19,143
That is exactly my problem here. Finding or even have the option to replace the speaker terminals is like you said PITA.
Can you post a picture? Thanks.
May 31, 2015 at 11:50 AM Post #14,499 of 19,143
I have a pair of Sony TA-N77ES. Their speaker terminals are soldered to a board, which is a pain to reconfigure because there is not enough room for modern terminals.
May 31, 2015 at 11:56 AM Post #14,500 of 19,143
It boils down to your local DIY electronics part shop - or internet. Chinese produce one hell of a lot of types of speaker terminals, by some clever kludging it usually is possible to somehow mate gerbil with a kangaroo ...
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xspeaker+terminals.TRS0&_nkw=speaker+terminals&_sacat=0
May 31, 2015 at 10:03 PM Post #14,502 of 19,143
A real humdinger! No doubt, I know you'll meet the challenge one way or another. Me? I'm actually considering getting 'Baby Sinister' (the Sansui G-22000) refurbished...forgot the terminology we use here in the thread for that, I'm very tired. But anyway, will simply have my guy (Terry) handle it while he's in there!
FYI - My terminals are located on either side (L/R) of the box, as opposed to being together.
Jun 5, 2015 at 12:56 AM Post #14,503 of 19,143
What do you guys think of this headphone adapter made by Sony in the 70's that was designed for power amps around 100WPC?
http://www.head-fi.org/t/600110/2359glenn-studio/11610#post_11663649
Jun 5, 2015 at 12:27 PM Post #14,505 of 19,143
I can't quite understand it.  Why are there L and R volume knobs and why are there 2  X 1/4inch headphone jacks.  Are they both stereo or are they mono? Is the L and R knobs there to help balance the stereo coming out of one of the jacks? If anyone knows,  do tell, it sure looks like a cool addition to any Silver series 70s amp.
