Nice scope - hope it does the job for you. Mine is in kind of rough shape - needs calibration - but has worked ok to trace signals through vintage gear. Payed $44 shipped - so was not expecting much. At some point I may have it calibrated though.
I will tell the story of my as of lately
late Hameg HM203-6 scope some other time.
I was most seriously considering Philips ( Fluke in US ) scope PM3065 http://www.ebay.de/itm/SUPER-PREIS-Fluke-2-Kanal-100-MHz-Oszilloskop-PM3065-/350981635332?pt=Mess_Pr%C3%BCftechnik&hash=item51b822bd04 It has one deciding advantage - the contacts for amplitude and time base , the Aichille's heel of both Tektronix and Hameg mechanical switches, is carried out with reed relais in Philips/Fluke. MUCHOS more reliable.
Then this Tek 468 popped up; it is serviceable, it is rebuildable, even if digital storage part gives up ghost ( custom ICs, now unobtainium save for canibalizing from another 486), analog still keeps on going strong. So far, all I could find wrong with it is the anticipated mechanical switch problem, CH II does not give a damn at 20mV/Div setting -
nada. Deoxit & all that jazz imminent, I am afraid. I bid trully
a hair above the winning bid of EUR 121. That did include two Tek 100 MHz probes, in themselves worth a good chunk of money. Shipping is not comparable between within US and from Germany to Slovenia, while although most probably shorter distance in most cases, is international shipping and did cost EUR 32 alone. Tek 468 is no object for ladies to carry, either ...
I intend to replace each and every cap to analogsurviver standard (as high as it can phisically be fitted within volumetric constraints) and then have it calibrated. I expext THAT calibration, with superiour and much longer lasting parts, will require little if any re-calibration for considerable time to come.
It DOES have one drawback - the fan impersonates hurricane scaled down quite conviencingly - and this is the reason I will use it to try to repair my
QUIET Hameg scope ASAP; I learned A LOT about music/recording looking to the scope while listening to the music - an obvious impossibility with the Tek
Hurricane ...
