Benny-x
Hey guys and gals,
I've been looking into getting my headphones recabled, but I've got a few pairs of them and I found that I was looking at some real serious numbers just for some new cables that WILL look great, but MAY or MAY NOT do anything... That lead me to the DIY route, and well, I think I feel pretty comfortable here :-D
So here's the low, I want to do a pretty massive recable on 3 pairs of headphones I currently own and also prepare myself for the ones that will come in the future. I only have a single ended amp right now, but I will definitely be buying a balanced one in the near future because my source is balanced. So I want to make a system of cables that can be taken on and off depending on whether I'm plugging the 'phones into a 1/8'' portable rig, 1/4'' home rig, a dual 3pin-XLR home right, and single 4pin-XLR home rig.
To do this I will rewire all of my headphones from the inside out and have a 6'' tail from the right and left sides terminated in a male mini 3pin or 4pin XLR. From there I'll make various cables that have female mini XLRs on the headphone end and are terminated in 1/8'', 1/4'', dual 3pin-XLR, and single 4pin-XLR on the amp end. This way I can switch out the whole cable depending on what amp I'm using.
I'll make these cables:
[size=small] 1. 10' dual mini-XLR to 1/4''[/size]
[size=small] 2. 10' dual mini-XLR to dual 3pin-XLR[/size]
[size=small] 3. 10' dual mini-XLR to 4pin-XLR[/size]
[size=small] 4. 5' dual mini-XLR to 1/8''[/size]
[size=small] [/size]
[size=small] So now I have a few questions, the ones that are holding me up. [/size]
[size=small] 1. Is there any purpose in the ground wire of a headphone? By that I mean, when you have 4pin-XLR, from the drivers there is R+&R- on the right side, L+&L- on the left side, but there's no GRD wire. When you have 1/4'', from the driver there's R&GRD on the right side, L&GRD on the left side, and after the cable comes together there is R,L,&GRD. You might say "GRD to shield", but not all headphone cables have shields, do they? So, what's the purpose of the GRD wire? Is there any real difference to headphones which are wired up with them and ones that aren't? [/size]
[size=small] 2. When going from 4pin-XLR with R+&R- on the right side, L+&L- on the left side, and connecting to 1/4'' plug, what do you do with the wires? By this I mean you have R+&R-and L+&L- from your headphones, but only "R", "L", and GRD in the plug. So do you, for example, connect R+ to R and R- to GRD, and L+ to L and L- to GRD on the terminated plug/amp side of the cable? If so, is there a downside here where you'll get some feedback or something? [/size]
[size=small] 3. When you're going from 4pin-XLR on the headphones with R+&R- on the right side, L+&L- on the left side, and connecting to dual 3pin-XLRs, do you just leave the 3pin's GRD empty? So inside the amp's FEMALES there's R+,R-,&GRD for the right 3pin-XLR and L+,L-,&GRD for the left 3pin-XLR, but in the headphone cable's MALE 3pins the GRD actually goes nowhere?[/size]
[size=small] 4. The reason I'm wondering is because I need to know if I should wire the headphones themselves with dual mini 3pin-XLR tails or dual mini 4pin-XLR tails? These headphones are gonna be wired balanced, but does it improve or hurt anything to have balance with or without a ground(GRD)? Even if the answer is just a straight "yes" or "no", please think about it in respect to me wiring 3 sets of headphones that will have modular attachment cables based on one of these two pin layouts. [/size]
[size=small] 5. What happens when you take a set of headphones which are R+&R-and L+&L balanced and run them from an unbalanced amp? Do they work just as usual, only receiving power from one direction, for example R+&L+, and the other wires, R-&L-, just kinda hang out hooked up to their respective drivers like a ground wire usually does? Or is there some downside to this?[/size]
[size=small] 6. And finally, but very similar to the previous question, what happens when you take a set of headphones which are R+,R-,&GRD and L+,L-,&GRD balanced and run them from an unbalanced amp? Do they work just as usual, only receiving power from one direction, for example R+&L+, and the ground wires linking to the amp, and the other wires, R-&L-, just kinda hang out doing nothing? Or is there some downside to this?[/size]
[size=small] And boom, that's the end of my GIANT post. I've looked around for a while, but I haven't found much information in these ares. Sorry for making it so long and please ask me to clarify anything that doesn't seem to make any sense. I could whip up a drawing, which would explain MUCH BETTER than words, if any of it's unclear.[/size]
[size=small] Thanks a lot for reading through all that and for reaching out to a novice DIY'er in the making :-D[/size]
[size=small] Ben[/size]
