sawindra
- Aug 31, 2009
testing the v7 vivids pro; major upgrade from the v6 vivids ( yes they suck in comparison)
only thing to notice is ; the v7 vivids does have a slight presence effect
second issue..maybe it's me? the pins on the v7s are very stiff. I had problem putting the v7s in
my composeer 3x, so to avoid using force..i had to use the extra dip8 socket which is included, to
fit the v7s in first, before installing in the composer dac
