adydula
- Dec 14, 2010
Burson Audio FUN
Well I have received from Burson Audio a new headphone amp to me. In the past I have reviewed Burson's Audio Cable + and Pro, and have always liked the Burson products. They seem to build some really well liked and well built headphone amplifiers. For people that like to play and experiment with various op amps to see if there are any differences etc, the FUN amp I just received is the “cats meow” for this type of activity!
Imagine a company that is enticing you to open up the device and plug and play to your hearts content and your wallet can stand!. The circuitry is designed to handle a wide variety of op amps, from inexpensive to expensive... They even supply you with an allen wrench and a spare power fuse!.
All it takes is 4 small hex head screws to pop off the cover and see the internals! The build quality inside the unit is second to none. I have built and worked in the electronics industry and this is a top of the line amp. The circuit board is well laid out, and there is no BIG unsightly power transformer inside that will ever “hum” or have isolation issues.
The FUN is a class A headphone amplifier that again encourages Opamp rolling. There is also an added mic input on the front. The Mic input is straight wired to a Mic output in the back for less cable clutter if used in a desktop pc system. For me I use this amp as a headphone amplifier....there is no DAC inside. But the FUN can fit into a PC drive bay and connect to your PC sound card and headphones. For gaming and great audio as well.
Instead of the traditional AC power into a transformer then into a bridge rectifier and filtering to remove the AC component etc...Burson designed what they call Burson Max Current Power Supply or (MCPS). The transformer is removed altogether. Burson states that main power at 50-60Hz is within the frequency the human ear can easily discern. A traditional linear power supply charges and discharges 50-60 times a second. They claim this is too slow for audio amplification. Their MCPS increases the working frequency to 179Khz. Any noise at this frequency is well above the human hearing threshold of 20khz. They say this allows for a pitch black soundstage critical for micro-details to shine through. Now this is techno talk from Burson, and I am a real technical geek that always has doubted many if these claims, the end result to me is the proof in the pudding. I will tell you in this review whatever they are doing here has led to a really GOOD amp. Call it what you want, this $299 Class A gem, is very crisp and clean.....pitch black for sure.
So there is no need for those LARGE capacitors for AC filtering and hum reduction. This amp puts out 2 watts of power into 32 ohms. A day when size natters, or bigger is better, this little amp throws all that away for sure. So its a 4x Max Current Power Supply, symmetrical dual mono design, Class A, Two DIP8 sockets for op amp rolling, ELNA audio aluminum electrolytics, and Vishay Professional MELF resistors ( with a 1% tolerance and a +/- 50ppm/K). Then volume pot is an ALPS pot with excellent tracking, All this with a 5 yr worldwide warranty.
The unit is the same size as a CD/DVD PC Drive that fits into a 5.25” PC drive bay. Its power can come from a 12VDC 5A source from your PC via a Molex connector. If you want to use it as a standlone unit they supply a small external power supply that has a green power led. The backside has two sets of RCA plugs, input and output, this unit can be used as a preamp as well, the preamp output impedance is 25 ohms, and the head amp output impedance is 6 ohms. They supply you with a nice set of RCA cables as well and 6.5mm to 3.5mm socket adapter. Inputs require 2V RMS line level, mic input. The unit weighs approx 2kg.
Class A amps run HOT. I have run this FUN amp for hours with 600 ohm Beyerdynamics T1 R2 and the case is slightly warm, there are 4 power transistors for each channel mounted to the bottom chassis assembly. Nothing like some other Class A amps I have built and owned. Not even close to hot to touch. Great design here.
The front of the FUN has a nice small bue LED to indicate power on. Its subtle and does not blind you.
The aluminum case is a matte black finish and it exudes 'professional” to me....very well done, like the SR 71 blackbird finish at the Smithsonian at Dulles Airport! There are four small plastic feet on the bottom.
The volume knob is large and fairly easy to turn the ALPS pot...nice and firm feel when rotating it...again exudes good parts and good operation.
The unit at the entry price of $299 comes with a pair of NE5543 X 2 op amps. My unit had JRC 5534D's which are in the $10-$15 cost retail. They are a high performance low noise op amp well beyond the old 741's. The amp with my headphones was silent with the volume turned up all the way. With 32 ohms cans I did hear some very slight noise with the volume up at 3pm, way, way beyond any listening. Most listening with 250 ohms or higher are dead silent.
So how does it sound...I used headphones from 32 ohms to 600 ohms and all were easily driven. All sound great. I have only 7 headphone amps at present, been selling! The Burson FUN sounds as good and “better” than most of them, its that good. Beyer 1350's, T1's, Audio Technica M50x's, Grado 325i's,
Beyer T90's, Audio Technica MSR7's....and others. All sound great, of course I have a preference....
The first word, adjective that comes to mind is “clear”, then “transparent”, then “soundstage”, followed by “accurate”, “lifelike”...and all those lesser adjectives...then I kept thinking “how are they doing this?” Its that good / different..the old “I have to listen to all my music again stuff...” The bass extension on headphones like the Audio Technica MSR7's is really mind blowing! The bass is indeed tight and well controlled with all my headphones.
The FUN has no internal DAC, so I am feeding it with a Schitt Bifrost Multibit DAC which I like very much as well....its a wonderful pairing that is making this amp come alive for sure, but there is magic in this little FUN Burson amp!
I could go over many of the songs I use to audition headphones and head devices but suffice to say I and hearing new stuff from my old favorites in a very enlightening way. Its like I am there. The tonality of violin strings are lifelike and mesmerizing. The music is effortless, the amp is supplying enough power throughout the frequency range...clear crisp, dynamic, tight......etc.
Everything from the remastered Beatles, A Hard Days Night, Eva Cassidy's , Eva by Heart, and on and on are being amplified very well. Whats there in the CD is being heard accurately and musically with my T1's....oh gosh its that nice.
Ok the surpy stuff is over....:>) I have not used the mic input or the preamp outs. So I cant comment on them. As a headphone amp, Class A, its the cats meow IMO.
I have been listening for three hours now and just dont want to stop listening its that nice....There are a lot of choices in this price range $299. But if your looking for a great Class A amp, that allows you to swap out and roll to your hearts content op amps, like NOS tubes...the Burson FUN should be high on your list. I look forward to rolling in some of Bursons other discrete op amps as well...Its just FUN!
HIGHLY RECOMMENDED.
Alex Dydula
NOTE: I got up this morning, cup of coffee in hand, to see if the Burson Fun was still working as well as my first impression...Instant on and instantly the smile appeared on my face...Burson has a winner here!
HIGHLY RECOMMENDED.
Alex Dydula
