UtzY
- Dec 21, 2006
[size=medium]Built/design quality![/size]
I’ve decided to make this thread for all the people like me…who thinks that the built quality of a headphone have a very large percentage in overall quality!
For example I have currently own a Sennheiser HD595 and I was very happy with the sound until the headband started to crack! Then I started to realize that for me…a perfect headphone must be first o all STRONG…and must have little or no weak points!
This is not the case of HD595, now after all of this happened, I think these headphones are the weakest headphone in production... Looking from quality of materials used in production…the can looks like cheap plastic.
What I intent to do (and find out) with this thread?
Everybody knows that every headphone has a weak point in built quality or design (many have 2 or more). But many of these weak points can somehow be avoided.
Example of what I heard from this thread:
HD595’s -headband eventually it will crack (it feels it’s made from cheap plastic but the cans are not so cheap) I felt this on my skin… a cold shower (not all the expensive headphones last…and I think that HD595 is expensive…I just don’t have the money
Ultrasone headband had (have) the same problem (some people said that they had fixed this problem)…
HD650 have a problem with the connection (don’t plug in and out very often)…
Grado’s have a problem with the cable…the cable can rotate inside of the driver enclosure “Hair on drivers” is another problem in Grado’s land!...
Beyerdynamic are built like tanks (DT880 DT990…)
but even tanks have weak points ( the gas tank ) I’m sure you guys will find at least one weak point
Not to mention all the IEMs…
The aim of this thread is to prevent all of these things from happening! Because loving a headphone is first of all accommodate with his sound and to accommodate with the sound she must resist in perfect shape (usually like brand new)…of course am aware of the existence of the love at the first “sight”
but many don’t have this luck (not at headphones maybe)
I’ll start with the headband of the HD595…I have this headphone for 2+ years. The headband maintained the shape approximately 3-4 months after that the first cracks started to show. The main reason for this is the tension of the headband and the not so good design (Red Dot award). My friend has the same headphone and the same head size like mine (medium or medium to big) but he bought the headphone after a year. From the moment he bought it we unscrew a bit the screws visible at the headband and started to make making her wider. Don’t begin stretching from the caps… stretch her from where the model is written. (I’ll elaborate if you didn’t understand …me and my poor English
I hope this post is helpful for the HD595 owners…Just be “careful” with the headband!
Just think at a headphone that had give up and what you should do to prevent this…or if you don’t know just name the weak spots of the headphone and maybe another member has already the answer (I’m sure they have it)
Now guys is after you…find the illness of a headphone and cure it!
