Bit Perfect Audio from Linux
May 31, 2015 at 4:47 AM Post #346 of 544
trippeeyyy​
May 31, 2015 at 3:01 PM Post #349 of 544
  Where are you guys getting these cool graphs?  Are they plugins for Deadbeef or are they part of it hiding from me?
The top seekbar It's a plugin called waveform seekbar, the right plugin is infobar. All the rest is native from Deadbeef, and all was put together using the design mode.
Jun 1, 2015 at 1:42 AM Post #350 of 544
If you're on Arch Linux install these from the AUR:
deadbeef-plugin-musical-spectrum-git
deadbeef-plugin-spectrogram-git
deadbeef-plugin-waveform-git
They're from this guy https://github.com/cboxdoerfer
Jun 25, 2015 at 12:12 PM Post #351 of 544
So how exactly can I get 24 bit 88.2khz sound, which is an upconversion of 16bit44.1khz, out of my GeekOut 450 on linux? I know I can set the audio on Pulse configuration file, but heard it's not the best way to go about it. I don't seem to have the asound or asoundrc file for alsa. I have asround.conf_jack and _oss, but not just .conf.  I'm on Linux Mint 17.1 KDE.
Jun 25, 2015 at 1:41 PM Post #352 of 544
If you are using MPD, I find this : http://www.diyaudio.com/oldwiki/index.php?page=LINUX+Audio+MusicPlayerDaemon.
Jun 25, 2015 at 2:09 PM Post #353 of 544
Can MPD be used with Google Play streaming music? EDIT: Guess that's what GMusicProxy is for.
Jun 25, 2015 at 3:24 PM Post #354 of 544
No you can't MPD for a streaming flux, isn't a audio driver, but a music player.
You can use this link if you are using ALSA http://www.alsa-project.org/main/index.php/Asoundrc
Or just modifie this file $HOME/.asoundrc
pcm.device{
        format S32_LE or S24_LE (all format available http://www.alsa-project.org/alsa-doc/alsa-lib/group___p_c_m.html#gaa14b7f26877a812acbb39811364177f8)
        rate (your rate)
        type hw
        card (your card number)
        device (the output port used)
pcm.!default{
    type plug
    slave.pcm "device"
Jun 25, 2015 at 3:25 PM Post #355 of 544
pcm.device{
        rate (your rate)
        type hw
pcm.!default{
    type plug
    slave.pcm "device"
I can't find that file. I looked for it.
Jun 25, 2015 at 8:38 PM Post #357 of 544
Jun 25, 2015 at 8:52 PM Post #359 of 544
vim ~/.asoundrc
^ replace vim with your editor of choice :)
Then insert the above with the gaps filled in for your set up.
hope that helps.
Not sure what you mean by editor. I'm a total newb. Feel free to share screenshots. Thank you much btw.
Jun 25, 2015 at 10:43 PM Post #360 of 544
LinUX has several text editors available, depending on distribution.  Most have Visual Editor Improved, /usr/bin/vim, and/or GNU EMACS, /usr/bin/emacs.  Distros with GNOME have a Text Editor, /usr/bin/gedit.  The Advanced LinUX Sound Architecture Project has a comprehensive wikipage on asoundrc.  As an example, were I doing a direct program for the Realtek® ALC-889A sound chip on the Hot Rod gPC's™ Gigabyte® GA-MA78GM-S2HP, ./.asoundrc might look similar to the example below (thanks, kazcou, for the template):
Originally Posted by kazcou /img/forum/go_quote.gif
pcm.device{
        format S24_LE, S16_LE
        rate 48000,96000
        type hw
        card 0
        device 0
pcm.!default{
    type plug
    slave.pcm "device"
A list of available devices can be retrieved with the command:  aplay -l dump
