boodi
- Nov 19, 2001
I prefer the result of PPHS 96k resampler sometimes as it gives more bass , what a nerd
the SSRC on 96k / which results bass lighter / seems a more refined processing for all the frqs.
basic results to my ears , the sound is more smooth top to bottom , but also less dynamic and less upfront ( also where it probably meant to be upfront )
have to agree that is quite good for ex. for old rock recordings that need some polish cream
and also separation of instruments seems to improve sometimes
Originally Posted by Mr.Radar The SSRC resampler is one of the best free resamplers out there. Compared to the resampler in the ASIO output plugin for Winamp (set to the highest quality mode) it isn't quite as good, but that resampler also uses much more CPU. The PPHS resampler for Foobar is slightly lower in sound quality than the SSRC resampler (though they're still very close, I can't tell the difference between them), but it's quite good for the amount of CPU it uses. The SRC resampler (one S) isn't very good compared to either the SSRC or PPHS resamplers, and it uses the most CPU. |
