lantian
- Dec 14, 2016
Problem with the original axon and axon mini is that they have no microsd expansion, other than that they should be pretty good
The distortion I'm talking about it the phase shift that different bandwidths set by the unit under test. All of them are likely to have a low pass filter after the DAC, and perhaps the amp, and some may have a high pass filter in the low frequencies. This will cause different phase shifts for each unit, which will be measured as a error. It is an error, but is it one you want to include? It will swamp the others distortions I suspect.
I wasn't criticising the Pink Floyd as a test. Just saying for a re-issue the quality is disappointing compared to some
Ok, scratch that the axon didn't have any but mini did have sd support, well the difference is also down to the dac and it's implementation.
Click the image and click "Original", should be in high res
Oops. I forgot the X3 Lite had Mediatek. Yikes. I don't understand how that phone can sound so good with a Mediatek SoC but then it also has this.
I have listened to a lot of cheap phones with Mediatek SoC audio and they nearly always sound underpowered, weak, and just lifeless when playing music. Even speech is a bit difficult to understand with my aging ears unless I have unusually sensitive IEMs. But probably this idea that Mediatek has one particular sound and Qualcomm has another is an oversimplification. There are probably differences between different SoCs from the same manufacturer as well as differences due to surrounding circuitry and other tweaks even with exactly the same SoC model. I have reason to believe for instance that the early Qualcomm 400/410/415 series had particularly strong/powerful audio which may or may not have been tamed down a bit in later chips.
I guess what that means is that unless it has been vouched for by headfiers you really have to listen to any phone before you buy it. Having said that almost every Mediatek SoC phone I have personally heard has had that anemic sound when compared to Qualcomm SoC phones. The only exceptions I have noted have been the Acer Liquid Zest and some Qnet (Philippines only) phones which have somewhat better and louder audio than most of the other budget Mediatek SoC phones I've heard. Nevertheless they still can't compete with phones like Lenovo A6010 or Vibe K5, Xiaomi Redmi series, or the Asus phones with Qualcomm SoCs and probably not with the ZTE phones that have Qualcomm SoCs either. So it's a useful rule of thumb I think, but no doubt there will be some exceptions especially in the case of the X3 Lite which probably benefits a lot from the Cirrus Logic / Wolfson WM8281 chip which does appear to be a physical IC rather than just software/firmware.
The headphone jack on my latest phone has just gone single channel so I am planning to buy yet another phone. It could be an opportunity to try out the PPTV King 7 that I have had my eye on, but right now my money is pretty tight so I'm not sure I can justify it when it will probably only last 3-4 months before the headphone jack goes intermittent or single channel on me and I am not too confident of sending it to China to get warranty service. The ZTE Zmax 2 would be a no-brainer but I would have to have it shipped from the US raising the cost from $50 or so to at least $75 with some chance of it not arriving at all and it doesn't have most of the local UMTS frequencies making it almost unusable for internet. So after my discovery of the $60 (flagship) Qnet phone that looks pretty good I think I am going to do an exhaustive listening comparison of all the ultra-budget 5.5-6.0" Mediatek SoC phones available locally. I'd like to make a list of phones using an Mediatek SoC audio path that have at least somewhat decent sound quality. A very short list I think
I'm tempted to just buy some sort of USB DAC+Amp device from Audioquest or Fiio so that I can hopefully just plug it into the usb port of one of these phones to keep using it when not if the headphone jack breaks, but I'm hesitant. I really like to be able to charge the phone while listening/watching and I am not at all sure about the whole chain of devices I need to do it and how reliable they are or how large or portable etc. Going with external audio processing would probably allow me to keep a phone for much much longer though. Even after the warranty expires. Maybe years. I haven't had any reliability problems at all from the cheap Chinese brands I have been buying except for the headphone jack and on the Flash Plus 2 an intermittent microUSB slot connection but that was defective from the start (another reason why I will try to avoid ever buying another device from Alcatel/Flash).
I am really starting to think however that Apple and LeTV sort of have the right idea when it comes to these pathetic 3.5mm jacks which always seem to break at least when implemented in these ultra-thin phones. Probably a manufacturer would have to go out of their way to intentionally design them to be more durable and that might require a thicker phone which of course they are not going to do. The headphone jacks on my portable CD players, Sansa Clips, Clip+, and even the Fuze+ seemed to last a long time: measured in years and not months or weeks as with all of the smartphones I have tried so far. It's hard to know if it's a design flaw inherent to 3.5mm jacks mounted on thin PCBs in thin phones or just an implementation problem that the cheap Chinese brands I have been buying have. The only well known brand smartphone I have owned was an Asus and it got stolen after only 2 days.
Sure, but then there is the issue of carrying around more than one device.
And for some people that one device to carry around may be too much already.
Just my 2c.
My Lenovo X3 Lite is over 6 months old, used heavily every day, earphones plugged in and out regularly and so far, no problems. However, when it breaks down one day, I will have no heart attack. Expensive phones, no thanks!
