aRaccoon
- May 28, 2016
how do the axon 7 compare to the LG V10
Interested in getting the Note 7.
Has anyone compared the Exynos to the Snapdragon 820 for sound quality with a sensitive IEM? Using the 1964 Ears A6.
I currently have the Note 5, and want to make the upgrade.
I think both will be a downgrade to your Note 5, which has excellent audio quality. The Note 7 appears to be the same as the S7 and that was definitely a downgrade to the S6/Note 5.
-Collin-
It used to be (S4) that Exynos needed a decent Wolfson DAC/headphone amp, and the qualcomm thought it was good enough (but wasn't, especially then when the charge pump crapped out into <18 ohms). So it depended on which region you lived in.
I'm not sure if that still applies. It should be noted that Sony and HTC all add something on top of the qualcomm processor for the audio.
So maybe the exynos version sounds good?
Set volume steps to 40 or 50 in UAPP to make it a little more bearable (50 seems to lower the max volume quite a bit, which isn't such a bad thing) - however, do you agree with me that the tonality is vastly different between UAPP and 'Hi-Fi mode'?Quick update Duncan: I put the phone in airplane mode and connected to WiFi and tried UAPP again. Holy cow that is loud! I know the hardware volume is locked at max, but even with the software volume at like 25% it is MASSIVELY powerful. I knew this DAC was capable of driving earphones to these levels, but it still irks me that we have to use these workarounds.
Anyway, I'll do some more listening, but this really sounds like the way to go despite the issues. Thanks for the heads-up on this.
-Collin-
Hello
First of all I'm not a true audiophile and I apologize to present my question here looking advice from good people.
I'm interested in purchasing a smartphone with a really good sound.
I'm searching for a HTC One M8 but I want to hear your useful opinion about other brands.
My daily use will be with V-Moda M-100 headphones + Fiio E12 + Neutron player and maybe V4A.
Sorry for my english if something is wrong.
Regards
[COLOR=111111]has anyone listened to with headphones as it sounds Xperia Z3?[/COLOR]
Never heard Htc one M8, but if you are looking for a smartphone with good sound the answer is simple HTC 10. But it's also rather expensive. Check the dedicated tread.
Hello
Regards
LG V10, Lenovo Vibe X3 and Vivo x series (if avail in your country), Sony X Performance, OPPO Find7/7a (if avail in your country)
I assume you can't find xiaomi/ meizu/ Letv easily right?
Please tell me if there is other brands avail in your country. I can scan that for you.
