jonyoo
- Apr 5, 2013
JVC FXZ200, T-PEOS H-200, Atomic Floyd Mini Darts, Westone 3.
Those would be my choices not in any particular order.
The JVC FX700 offers really deep reverbing bass but new FXZ200, GR07 BE are also great buy under your budget.
There are JVC HA-FX700's on ebay for around $250. Does anyone make fakes of the FX700's?
Wouldn't mind paying that considering the $-£ exchange rate is fairly good at the moment.
Actually it isn not that cheap. In japan it costs $180. So with Tenso forwarding service it is about $200-205 to UK. But there maybe can be import tax.
http://www.amazon.co.jp/s/ref=nb_sb_noss_1?__mk_ja_JP=%E3%82%AB%E3%82%BF%E3%82%AB%E3%83%8A&url=search-alias%3Daps&field-keywords=fx700
Had the GR07 BE. Great sounding headphone but 'slightly' lacking in the amount of bass i'd like. Would have bought a new pair once my old ones broke but they aren't really that handy on the go as they look funny and my wire kept slipping from around my ear.
If you're looking into JVC, you should find them cheaper on Amazon Japan. Got my FXZ200 for $190 and its perfectly fine!
Can I buy from amazon JP in the UK?
+1 for the Wooduo.
Wouldn't really call the 7550 bass oriented. After all, they're marketed as a reference series IEM...
