biosailor
- Jun 2, 2016
Love the Benchmark AHB2, it's a neutral window to the music - it just sounds right to me. It's also compact, cool running and sounds great from switch on - which makes it extremely practical.
The competence of the AHB2 has given me the confidence to buy the HPA4 and I've also ordered a DAC3 L to complete the chain.
To be honest I'm sceptical whether the HPA4 will show significant improvement over the BP26, which itself has distortion levels an order of magnitude below typical hifi gear. The HPA4 boasts significantly higher S/N ratio, though whether this will translate to any practical advantage remains to be heard. At least I'll reduce my box count.
Thanks for the update regarding the AHB2. It certainly is an amp that I'll keep on my radar.
Concerning the HPA4: I hope to improve channel tracking at low volumes. With my present pre-amp, I get the feeling that at low volumes, there is a bit of a channel imbalance because it uses a conventional potentiometer (although a high-quality Alps pot). The HPA4 seems to have an elaborate system of volume control. I like their approach. In addition, I am hearing a slight hum (even though not audible at listening distance) that I hope to remove with the HPA4.
