philodox
- Dec 12, 2003
FYI, the Opera Consonance Cyber 20 is one of the worst amps I have ever heard. It is no wonder that the Bada PH-12 beats it.
Originally Posted by drarthurwells Art: Thanks for your input. My Chinese audiophile friend, who recommended the Bad a PH12 to me over the Opera Consonance Cyber 20 which I had been considering, confirmed again what the Bada chief designer originally said about the Bada PH12: "PH-12 EMPLOYS NO GLOBAL NEGATIVE FEEDBACK AND IS IN SINGLE-ENDED CLASS A, HIGH POWER DESIGN, THE CAPACITY OF CAPS IS NEARLY EQUAL TO A MINI AMPLIFIER. THE MUSIC CHARACTERS OF PH-12 IS A GOOD MIDRANGE COUPLED WITH GOOD HIGH AND LOW EXTENSION - WITH WELL BALANCED FULL RANGE AND WIDE SOUNDSTAGE. IF COMPARED WITH THE FAMOUS OPERA CONSONANCE CYBER 20, PH-12 OFFERS BETTER EXTENSION AND SOUND STAGE, OVERALL FEELINGS OF BALANCE IS NOTED IN PH-12. SINCE CYBER 20 IS USING TRANSFORMER OUTPUT AND SO THE SOUND IS DEPENDED ON THE TRANSFORMER QUALITY - IT IS THUS NOTED THAT THE HIGH AND LOW EXTENSION IS A BIT RESTRICTED AS WELL AS THE SOUND STAGE IN THE 20." |
Originally Posted by Solude Don't think I saw it anywhere but Rudistor tube amps are also tube/ss hybrids and quite a bit less than $2000 I might add. |
Originally Posted by drarthurwells Thanks again for the info. The Bada chief engineer said to my Chinese audiophile friend that the PH12 was a single ended class A amp using no global negative feedback. It uses three 6NS7 triod type tubes. I put these two things together and mistakenly called it a single ended triod (SET) amp. |
Originally Posted by drarthurwells I got a total quote with the total order well over $2,000 |
Originally Posted by jjcha I'm not a fan of the Cosmic, and unfortunately, I have not heard the other amps you reference in your review. Have you listened to other amps that would give us a frame of reference? I think Ray Samuels' entire line is a good reference, if only because so many of us are familar with them, as well as the Gilmore amps. Best regards, -Jason |
Originally Posted by Ferbose Aren't some folks adding OP-amps to the famous RKV nowadays |
Originally Posted by drarthurwells Quote:
Art: Now that sounds interesting - I assume, though, that it is not an OTL design but uses a transformer in the output. Any owners care to post about it? Any owners in Florida (North or Central) that would want to compare with the Bada PH12? What about other hybrids available beside the Bada PH12 that are also an OTL design? |
Originally Posted by drarthurwells I assume You refer to your Jolida integrated hybrid speaker amp that you use with headphones. Does it have a headphone out? Is it Class AB instead of Class A? |
Originally Posted by Ferbose Every hybrid amp is an OTL design, basically. Hybrid amps use transistors for power amplification, which don't need output transformers to begin with. When people say OTL, they are always talking about amps with tubes for the final output stage (power amplification). Amps with transistors for power amplfication naturally don't have output transformers, at least I have never seen one. Saying a hybrid amp is OTL is almost like saying a CD player does not incorporate a tonearm. And OTL is not such a big deal anyway. Many tube amps with transformers sound great as well. There is really nothing special about BADA's circuit topology that guarantees good sound. An amp does not need any exotic circuit topology to sound good. In fact, Ray Samuels once said, every audio circuit has been reused a million times. |
Originally Posted by drarthurwells Confusing to me. Please clarify: The BADA has a huge capacitor (3 inch high and 5 inch diameter), given it does not use an output transformer, like the Single power Supra OTL does, and other tube OTL designs have. The huge capacitor is in lieu of a transformer of some sort, I assume, making it an OTL design in addition to the OTL of its MosFet output. Do all hybrid headphone amps feature this big a capacitor, given, as you say that they don't use any transformer in the output? The Bada is the only one I know of tha tuses this huge capcator. Why then does it need such a huge capacitor? If Bada did not use this big capacitor then they would have to use a transformer instead, right? Going back to SACD lover's comments below: Tubes excell at voltage delivery while solid state excells at current delivery... which is the whole theory behind combining these two different amplification devices. The highest amplification factor usually occurs at the votage gain stage.... thats why the tubes can signifigantly impact the sound. From this can we say the Bada is a tube transformerless design, in the voltage gain stage of amplification, and this is unlike other hybrids that use a large transformer instead of the Bada's huge capacitor? Again, I know of no other hybrid that uses a huge capacitor like the Bada does. Finally, you seem to say that circuitry can be disregarded, it is how a design is implemented and not what the design is. Class A is as natural in timbre as AB? And what about the irritating switching distortion of Class AB that results in listener fatigue? OTL is not more natural a sound in tubes than is transformer output sound? I have seen where experts say the opposite, though dynamics are lacking in tube OTL amps. |
