Beefy
- Mar 4, 2008
And this is a constant current through the caps, given the Class A output stage? So whatever goes from ground to the positive rail would come from the negative rail to ground? All constant current still?
And then you go ahead and dump the reactive and changing return load right from the positive rail right on in there, and source the negative rail from there. Constantly pumping into and drawing from the ground.
OR, you dump the reactive and changing return load from each rails into each other. Sure, the current still has to cross over the ground, but never dumps directly into it or draws from it.
For the reservoir caps right after the rectifier - sure, this is exactly what happens. But what about the local reservoir caps? Theoretically, with clean DC coming at them they should never discharge and need topping up.
Originally Posted by Koyaan I. Sqatsi /img/forum/go_quote.gif You can't draw current from one plate of a capacitor without an equal amount of current flowing to its other plate. And the only way for that to happen, given that both reservoir capacitors have one of their plates tied to the ground node is for that current to pass through the ground node. |
And for just a brief moment every 1/120th of a second (or every 1/100th of a second if you're AC is 50 Hz), the battery charger gets plugged into the batteries to recharge them, and then it gets unplugged, such that for the majority of the time, the battery charger is not plugged into the batteries. |
