Hi (new Bravura owner & Head-fi member here) ... where did you find a Bravura manual that goes into that kind of detail? the one I downloaded from the Auzentech site is *very* brief and doesn't describe the mode buttons. The manual I have is "BRAVURA_MANUAL_2010-02-10_Eng.pdf" from
http://www.auzensupport.com/site/download/manuals.php .
And, on a second note, I (just installed a few hours ago) haven't found yet how to configure the device so I can manually select between speakers & headphones. I have my phones (Sennheiser 595) plugged into the back panel jack. I have a pair of Klipsch promedia 2.1 speakers plugged in as speakers for now using the "green" jack. The only way I've found to switch between them is to use the Windows audio control panel. According to the manual Section 4.1, there should be a button on the Console Launcher (headphone section) to select which output to use. But mine has no such control. Furthermore the large volume control and the small headphone volume control on the front panel both control only the speakers/headphones (whichever is in use at the time). Aren't they supposed to control the two seperately?
I installed the driver v1.35 from Sept 10th.
Thanks!
p.s. anyway I am testing with the 'phones and they sound amazing! I keep removing the headphones thinking somehow the speakers are playing by accident
. And I keep hearing things in the music that make me think, "oh wow!"
