I'm a huge fan of the Mojo because of it's high price/performance ratio. The
measurements are far better than most very expensive DACs and I find the SQ to be very good compared to other typical desktop DAC solutions, even much more expensive ones that use typical 'off the shelf' hardware. I don't think you'll find a better solution,
technically, for less than 3x the cost and above, IMO, certainly not at a lower price point. I suggest you head over to read the
third post of the Mojo thread - Link - (especially the section titled 'Detailed & in-depth Information on Mojo, by Rob Watts (Mojos designer)') to understand the technical reasons why the Mojo is different than other DACs. It's A LOT of information.
The warmth and smoothness is actually down to a lack of noise floor modulation, which has been shown to spice up the sound that is typically heard in DS DACs making them seem brighter and more detailed, but it isn't more detail. The same smoothness is found in Chord's DAVE (which I also own) but the DAVE has even more resolution and even better timing than the Mojo due to the better WTA filter and more Pulse Array elements (the actual DAC part of Chord's DACs).
