- Jun 22, 2001
I must refer back to Jude's post again. To sum up, because my equipment, software, and techniques are different than Tyll's we cannot compare my measurements with his, especially since his measurement include noise (THD+N). On a side note, I think there may be some problems with Tyll's THD+N measurements since every graph (as far as I can tell) has a sharp peak at 200Hz and another at one decade higher (2kHz). I don't have an explanation for why his charts all have this characteristic, but it must be some artifact of the measurement system and definitely not a characteristic of the headphones themselves.
IIRC Tyll has mentioned that those are artifacts relating to something in his test gear switching ranges and to just ignore them when reading his data.
Yup. There's a glitch when the ranges change and AP says there's nothing I can do about it.
I would say the THD+noise measurements I take can be quite problematic. All that has to happen is a truck going down my street and you'll see a raise in the THD+noise measurement....damit.
It's one of those things that if I change the way I do it, I'd have incompatibilities with all the old tests. I'm going to be writing the interpretation of my THD+noise plots article soon and will be pointing out the areas that are suspect and where the measurement can usually be trusted. Kinda sad, but I can only do the best I can do.
