Audioexcels
- May 31, 2006
OK, I might be wrong: let's say my system is not transparent, my headphones are no good to reveal that and audiophilleo is ultimately flawed...
Just to appease my scepticism - can you please describe your system (from software player to headphones) with which you can so easily spot audiophilleo's flaws hiFace's equality and OR4/5 superiority?
Both my system, Steve's (Empirical Audio), even a friend of mine's, have all revealed the issues, but we all have different two channel home systems. I have heard very high end headphone setups, and they are no were near the same level of resolution/detail/name your adjectives of a two channel home audio system. With this in mind, the differences between these transports will definitely be heard, but it probably will not be a deal breaker if you know what I mean. It is certainly a deal breaker when you are wanting all that a high end two channel or even a mid range two channel system can give you because you hear every little thing and those truly annoying things can and do become bothersome OR in this case, just do not fit into the system without reducing the sound of it. When something reduces the sound rather than simply give a different sound, that's not a good thing. I am absolutely confident that even VERY EXPENSIVE usb based computer stuff out there will struggle to keep up with the OR5 and I bet these devices will show off enough inferiority that I would place them in that same category of being flawed somewhere. So you see, the Audiophilleo may not even be that bad and may even be up for the test against much more expensive other USB interfaces, but it's just not when going against either OR4 or OR5.
