razor5cl
- Apr 6, 2013
I'm going to get them from Accessory Jack. I just have to return a faulty item I bought and I'm going to use some of the money from that to get these.
Glad you liked them.
At first it can be a bit uncomfortable. After a short period of time the comfort issue is going to be almost nonexistent as you will probably find the best position in your ears. This is what I experienced. About the filter mod, it is barely noticeable if you use the stock tips. With some soft and wired bore tips the differences are more pronounced.
How about the subbass, is it better on IM70s?
Originally Posted by surge /img/forum/go_quote.gif
also tried the im04, while it has better separation and greater details, at that price, the choice is plentiful and there are many iems w similar price.
Did you have a chance to listen to IM02? I really have my mind set on that one, but can't figure out from all the reviews about it's bass quantity. Would have been interesting to find out how this dual driver compares to dual driver models IM50/70.
I did listen to IM02. I think the bass and also the sound signature are quite comparable. The bass amount is almost same on both IM02/IM50 while IM02 seems a little bit faster but not too much. Vocals are very similar too. They are both mid forward sounding IEMs after all. I couldn't see any reason to upgrade to IM02 after I listened to them. Hope that helps.
didnt try the im02 as i only had abt 20mins( which i bought im70... yes they were that attractive and still enjoying them very much, will be doing a heir 5.0 vs im70 match this weekend..for the fun of it).
would try the im02 this Friday. as for price, dynamic drivers are cheaper to produce than the armature drivers(of cos apple-to-apple comparison, there are very expensive dynamic drivers too). i got the im70 as have always found sound of dynamic drivers more cohesive and live like. armature drivers can produce better details separation etc but its like different sounds coming from different mouth. whereas dynamic drivers are like all the freq. coming from the same mouth. better if it is a single full range driver(by far the best speaker i listened to is a full range field coiled 12inch feastrex) the sound is integrated,there is no interest to pick out the highs, mid lows etc unlike separate drivers. The same i felt about dynamic drivers.
so far IM70 has not dissappoint. btw the highs are a bit recess compared to the mids and lows, which helps expand the soundstage a few steps back. not a bad thing, if not the sound would be to forward.
my wife was quick to correctly guess the price of the im70(to be sub USD100...the give away,,,she said the cable looks cheap.
considering the rest of fancy cables on the other phones...the im70 cables look more like wires than cables...no complaint....just an observation by my wife.
Perhaps the next logical step would be to have a hybrid IM20h with one of the dynamic drivers from IM50 and another balance armature from IM0x series This way we can have the best of both worlds with a decent bass and mid/treble clarify.
A bit concerned about wires quality per your comments. Hopefully there will be aftermarket versions. I absolute love my RC-SE1 mini-coax replacement cables (for UE900 and W40), and can only hope FiiO will make one for ATH replacement.
I hope there'll be some aftermarket cables too. Not for sound quality, but for mic controls and cool colours and materials.
