iponderous
- May 19, 2009
Thanks for your response tstarn06, I await your comparative impressions of the CK10 and your custom TF10's with interest.
Originally Posted by iponderous /img/forum/go_quote.gif This thread is beginning to do my head in. |
Originally Posted by mp3 /img/forum/go_quote.gif I use mine with trimmed Shure tri-flanges, and they are very comfortable. Also, they can be used with the foam-hybrids supplied with Brainwavz Beta and decored Soundmagic PL50 foam-hybrids. |
Originally Posted by iponderous /img/forum/go_quote.gif ^ Do they feel less comfortable than the other universals that you've owned? I've never experienced any problems fit or comfort wise with any of mine. |
Originally Posted by tstarn06 /img/forum/go_quote.gif You mean the white Shure flanges? Trimmed to two? I have those on hand, gave away my Betas and never had the PL50s. But I can try the Shures. Didn't think you could stretch them on, but I will give it a try. Right now I have the CK10s on down, and the large stock tips are giving me a good seal, no discomfort. May be my solution. More listening ahead. Now trying the small tips over the ear, didn't plant them so deep, wet them first, and I think I might have hit the right combo. I mean, they are not "invisible" relative to customs, but they are not painful either. Just different. I need to wear them for an hour or two and see how it goes. Meantime, the sound is superb, much what some have posted here. Details, crisp, but I still am using the Sony Clear Bass EQ, personal preference. They do not sound "thin" or sibilant right now, far from it. Listening to a track from Johhny A called Oh Yeah. Highly recommended. |
Originally Posted by mp3 /img/forum/go_quote.gif Yep, the white tri-flanged Shure tips, PA755, they can be stretched to fit. I let them remain tri-flanged but cut off the stem so it sits flush with the biggest flange. |
